[AG-TECH] RE: Dual Boot PIG
Adam Hanson
hanson01 at scl.ameslab.gov
Tue Mar 30 11:30:16 CST 2004
Hey, (WINXP/LINUX)
Alright, I spose I'm having a little difficulties with this. First,
I was able to transfer the cert files over to the linux platform from
windows easily. I found the locations of where the files should be and
replaced them. That didn't work smoothly and I ended up having to
import them. I imported my windows Ident Cert, as well as both trusted
CA Certs (Access Grid Developers CA and Globus Certification
Authority). As well note, I did this through the VenueClient.py. Now,
when I first start up the VenueClient, It prompts me for a password.
The Personal Ident password does not work for this. As well when trying
to start AGServiceManager.py, the same problem occurs. This is a fresh
install and no other passwords have been declared. I tried starting
from scratch again, this time I requested a new certificate. The same
thing occurs here as well. If needed, I'm doing this install on a
Debian Platform Kernel 2.4.18, with python 2.2.1, AG 2.1.2. Anyone
have any suggestions? It would greatly be appreciated. Oh and on a
side note, when everything is set up and I bypass the first password
that denies me access, I'll try to join a server, it prompts for
password which will accept ident password, and then it specifies that
the venue server is unavailable...
Adam
