[AG-TECH] AG 2.1.2 problems under Windows XP
Darran Edmundson
darran.edmundson at anu.edu.au
Fri Mar 26 02:06:56 CST 2004
I "upgraded" our display machine from W2K to XP
the other day and have since been struggling trying
to get AG2 running.
1) vic is crashing with a runtime error when enabling
transmit mode. I've got a single svideo camera
plugged into an Osprey 100 capture board. The board
works, the WDM drivers are installed, and I can
use the camera under NetMeeting, vidcap, etc. The
vic menu shows this device as "Microsoft WDM Image
Capture (win32):
$ cat videoresources
device: Microsoft WDM Image Capture (Win32)
portnames: external-in
Works fine under linux (bttv driver) and W2K (probably
VfW driver?) Works fine here under XP for watching
streams, just not transmitting.
2) Globus config problems:
$ python AGServiceManager.py
No handlers could be found for logger "AG.CertificateManager"
There are no certificates loaded; application cannot use
Globus communications AGServiceManager URL:
https://ag0-display:12000/ServiceManager
I've run globus_init.pyw and configured globus to use the
same certificates as before. Under W2K, starting
AGServiceManager prompts me for the certificate passphrase
and creates a proxy certificate.
Any help is much appreciated.
Cheers,
Darran.
Darran Edmundson (darran.edmundson at anu.edu.au)
ANU Supercomputer Facility Vizlab
Australian National University, Canberra, ACT 2600
tel: +61 2 6125-0517 fax: +61 2 6125-5088
