[AG-TECH] AG 2.1.2 on Win2K Professional?
Randy Groves
randy.groves at boeing.com
Thu Mar 25 10:44:13 CST 2004
(The original note, plus some more information on the problem ...)
Attached are the VenueClient.log, CertificateRequestTool.log and the errors
that occur when I try to run CertificateRequestTool.pyw manually in a
command window.
I thought that I'd gotten this to work in the past, but my present
experience makes me doubt that, and the fact that the web site claims that
this is unsupported makes me doubt it still further. What it looks like is
happening is that the venue client tries to start up the
CertificateRequestTool and then hangs for good. This is from looking at
the log files. On the surface, the client gets as far as 'Verifying the
globus environment' and that is all she wrote.
Which also brings up a question - does the Globus configuration dialog do
anything in the present incarnation of AG? I've ignored it since the newer
cert management stuff and as an attempt to fix this non-functioning
installation, tried to configure the certs with this - it seems to accept
my inputs just fine - but doesn't make any difference in the action of the
venue client. Clicking on 'Run Grid proxy init' doesn't result in any
action once I've set up my cert.
Starting the venue client in debug mode results in an empty command window
and a venue client that still gets to the 'Verifying the globus
environment'. It doesn't matter how long I wait - it doesn't proceed.
So - is Win2K really not supported?
-randy
03/24/04 14:49:27 1280 AG.DataStore datastore.py:1615 DEBUG Creating thread 0
03/24/04 14:49:27 1280 AG.DataStore datastore.py:1620 DEBUG Starting thread 0
03/24/04 14:49:27 1764 AG.DataStore datastore.py:1628 DEBUG Worker 0 starting
03/24/04 14:49:27 1280 AG.DataStore datastore.py:1622 DEBUG Waiting thread 0
03/24/04 14:49:27 1280 AG.DataStore datastore.py:1625 DEBUG Done creating workers
03/24/04 14:49:27 1280 AG.DataStore datastore.py:415 DEBUG Reading persisted data from: C:\Documents and Settings\robinson\Application Data\AccessGrid\personalDataStore\DataStore.dat
03/24/04 14:49:41 1280 AG.toolkit toolkit.py:54 DEBUG userConfigDir: C:\Documents and Settings\robinson\Application Data\AccessGrid
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:247 DEBUG Opened repository C:\Documents and Settings\robinson\Application Data\AccessGrid\certRepo
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:963 ERROR No identity certs found
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:659 DEBUG Unlink C:\Documents and Settings\robinson\Application Data\AccessGrid\trustedCACerts\42864e48.0
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:659 DEBUG Unlink C:\Documents and Settings\robinson\Application Data\AccessGrid\trustedCACerts\42864e48.signing_policy
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:659 DEBUG Unlink C:\Documents and Settings\robinson\Application Data\AccessGrid\trustedCACerts\45cc9e80.0
03/24/04 14:49:41 1280 AG.CertificateManager certificatemanager.py:659 DEBUG Unlink C:\Documents and Settings\robinson\Application Data\AccessGrid\trustedCACerts\45cc9e80.signing_policy
03/24/04 14:49:41 1280 AG.CertificateRequestTool certificaterequesttool.py:62 DEBUG __init__:Start Certificate Request Wizard
2004-03-24 14:14:40,391 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:18:23,918 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:22:31,351 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:29:35,361 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:33:09,724 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:42:39,533 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:45:16,490 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:46:32,375 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
2004-03-24 14:49:41,440 DEBUG __init__:Start Certificate Request Wizard (certificaterequesttool.py)
C:\Program Files\Access Grid Toolkit\bin>python certificaterequesttool.pyw
No handlers could be found for logger "AG.CertificateManager"
Traceback (most recent call last):
File "certificaterequesttool.pyw", line 87, in ?
Main()
File "certificaterequesttool.pyw", line 83, in Main
app.gui.HandleNoCertificateInteraction()
File "C:\Python22\Lib\site-packages\AccessGrid\CertificateManagerWXGUI.py", li
ne 330, in HandleNoCertificateInteraction
self.RunCertificateRequestTool()
ne 337, in RunCertificateRequestTool
createIdentityCertCB = self.CreateCertificateRequestCB)
File "C:\Python22\Lib\site-packages\AccessGrid\CertificateRequestTool.py", lin
e 73, in __init__
self.page5 = SubmitReqWindow(self, "Submit Request")
e 938, in __init__
self.proxyPanel = HTTPProxyConfigPanel(self)
e 889, in __init__
self.proxyEnabled.SetValue(defaultEnabled)
File "C:\Python22\Lib\site-packages\wxPython\controls.py", line 213, in SetVal
ue
val = apply(controlsc.wxCheckBox_SetValue,(self,) + _args, _kwargs)
TypeError: an integer is required
14:55:22: Debug: e:\projects\wx\src\msw\app.cpp(439): 'UnregisterClass(canvas)'
failed with error 0x00000584 (class still has open windows.).
