[AG-TECH] Firewall woes ...
Thomas D. Uram
turam at mcs.anl.gov
Thu Mar 25 10:56:54 CST 2004
Hi Nathan:
The current version of the bridge server does choose ports randomly.
The next version will allow the ports to be configured, to be more
friendly to admins with firewall concerns. If you're interested, when
it's usable in cvs, I can give you the info you need to try it.
As for the venue server, the default ports it uses are 8000, 8002, 8004,
and 8006.
You might also refer to this document about firewalls and the AG:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/agep/AGEP-0109.html
Tom
Nathan P Johnson wrote:
>I am attempting to run an AG 2.x venue server and bridge server on a
>linux box with an iptables firewall. The bridge server seems to use some
>ports it picks in an arbitrary fashion? How do I know which ports to
>open in the firewall for both the bridge and the venue server.
>At this point I seem to have things working partially. Any suggestions?
>Has anyone done this?
>Thanks,
>Nate
