[AG-TECH] Mute switch for AG.
Ed Ritenour
erritenour at lbl.gov
Thu Mar 25 10:32:31 CST 2004
Hey all
It is my understanding that there is a correct and incorrect way to wire
the microphones for muting to work properly. When wired incorrectly the
microphones can be muted but retrain and cause a echo when activated.
Ours do this, but to correct requires a different cable be strung to
each mic. I believe the wiring method is defendant on how the mic's were
ordered. It is my understanding that Gentner web site shows the correct
wiring method to prevent the echo.
Ed
Monika Rabarison wrote:
> Chris,
> Thank you so much for making this clear. I liked to keep the mike
> button off when no one is talking just to save the batteries :). Will to
> better.
> Cheers,
> Monika
> On Thu, 25 Mar 2004, Osland, CD (Chris) wrote:
>>Quick reply re using mute buttons on mics, and an additional reason
>>for NOT using them ...
>>Yes, the buttons work. Yes, the retrain time is quickish. Yes,
>>even 30 seconds is a long time in a tense meeting.
>>However, remember the ancient truth: the person causing an echo
>>problem is the ONLY person who CAN'T hear the problem. No apologies
>>about use of capitals in the above.
>>Hence, the person using the mute buttons is the one person who doesn't
>>hear any disturbance (large or small) that their action causes.
>>Cheers
>>Chris
>>____________________________________________________________________
>>Chris Osland Office tel: +44
>>(0) 1235 446565
>>Digital Media and Access Grid Medialab tel: +44 (0)
>>1235 446459
>>BIT Department Access Grid room tel: +44
>>(0) 1235 445666
>>e-mail: C.D.Osland at rl.ac.uk Fax: +44
>>(0) 1235 445597
>>CLRC Rutherford Appleton Laboratory (Bldg. R18)
>>Chilton, DIDCOT, Oxon OX11 0QX, UK
>>[The contents of this email are confidential and are for the use of the
>>intended recipient only.
>>If you are not the intended recipient do not take any action on it or show
>>it to anyone else,
>>but return this email to the sender and delete your copy of it.]
>>>-----Original Message-----
>>>From: cunningham at psc.edu [mailto:cunningham at psc.edu]
>>>Sent: 24 March 2004 17:32
>>>To: AG-TECH at mcs.anl.gov
>>>Subject: [AG-TECH] Mute switch for AG.
>>>My boss wants us to add mute switches to our AG so the users
>>>can mute and unmute
>>>as desired w/o operator intervention.
>>>An ideal system would either mute outside of the machines,
>>>(between Gentner and
>>>aud-cap), or toggle the mute within rat through an interface
>>>to aud-cap.
>>>I have no idea how the latter would work.
>>>There would be 3-4 momentary switches for our tables that
>>>would toggle the
>>>state from muted to unmuted or back with a touch of the
>>>switch. The system
>>>would also have an indicator that shows whether we're muted
>>>or live at any
>>>given point.
>>>Have any of you put together such a system or know if/where
>>>one is available?
>>>Thanks,
>>>Steve
> Monika Rabarison
> Systems Administrator
> Information Technology/HPCVI
> Jackson State University
> Office:(601)979-5933
> SciVis Lab:(601)979-1061
> JSUvisNode:(601)979-1056
> JSUeNode:(601)979-1081
