[AG-TECH] Questions about globus configuration
Robert Olson
olson at mcs.anl.gov
Thu Mar 25 06:46:33 CST 2004
You can work around this by setting an environment variable GLOBUS_HOSTNAME
to the IP address of your computer. You should do this via the System
control panel item.
--bob
At 06:30 AM 3/25/2004, NamGon Kim wrote:
>I am installing AG Toolkit to my own PC.
>But I have a problem about setting globus configuration.
>After executing globus Setup Wizard, I can go through the check globus
>configuration and certificate configuration.
>But while doing check network, I cannot go further.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040325/86516487/attachment.htm>
