[AG-TECH] winnov videum video card
Fred Dech
fdech at uchicago.edu
Fri Mar 19 13:21:53 CST 2004
hi Cindy.
the only way we could solve that problem is to install an inSORS plugin.
otherwise, we were only able to get 1 stream out of that card.
i guess the single card/multiple captures isn't quite compatible with AG2.
the plugin resolved that issue for us.
--fred
Oe Fri, Mar 19, 2004 at 11:05AM, Cindy Sievers said:
> I'm struggling with the winnov videum 4400 quad video card.......I'm
> getting close to having it work, but I have some questions.
> When I add a video producer service, then I try to configure that service,
> it doesn't see my video card (so I can't select from a list of video
> sources) The Service config dialog box says 'Resource none' and I can't
> type in this box to add my card. However, I can see one video
> stream. When I click on the menu option in the vic, select Device, I can
> see a listing of all the cards......I select a device and I can see that
> stream. If i add 4 video producers, edit the menu options on each, I can
> see all 4 streams.....but it's terribly time consuming....we don't write
> config files anymore do we?
> Has anyone else gotten this to work?
> Thanks!
> Cindy
