[AG-TECH] Re: Invalid Passphrase - getting closer!
Darin Oman
darin at ucar.edu
Thu Mar 18 12:37:59 CST 2004
OK, I got my new cert, installed it on both machines of my room node, and I ran into a new problem. I can now get into the Display/audio machine and all looks good there. I can also start the service manager on the video machine. I've checked the certs on both machines and they're identical and set to default. It all looks good until I try to connect the display machine to the video machine. I get "can't locate service manager..." The time on both machine is in sync, so I don't think that's the problem. Any ideas?
Darin
On 3/18/2004 at 10:06 AM Robert Olson wrote:
If you're running 2.x you can request one thru the cert request tool. Someone will be around all day that can sign it for you.
--bob
At 09:58 AM 3/18/2004, Darin Oman wrote:
Yep, it looks like the cert is expired. Is there a way to quickly get a new one, or should I change the date on the machine to make it through the day? I could also go back to AG 1.x, but I'd hate to have to move backward.
Darin
On 3/18/2004 at 9:31 AM Robert Olson wrote:
Try bringing up the cert mgr and have a look at your default cert; I'm wondering if it has expired. (latest code has a lot more detail on cert failures, btw, so this sort of thing will be more obvious).
--bob
At 09:13 AM 3/18/2004, Darin Oman wrote:
Hello,
I'm suddenly unable to log into a venue client on my AG2 systems. I've tried 2 (they use the same passphrase and I think the same certificate) and I'm getting an "invalid passphrase" message on both. Can anyone help?
Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040318/68b3741c/attachment.htm>
