[AG-TECH] Invalid Passphrase
Darin Oman
darin at ucar.edu
Thu Mar 18 10:23:36 CST 2004
OK, I requested one using the name "NCAR Main Node." Is that outside of standards? Should I have used my own name (like the previous cert)?
Darin
On 3/18/2004 at 10:06 AM Robert Olson wrote:
If you're running 2.x you can request one thru the cert request tool. Someone will be around all day that can sign it for you.
--bob
At 09:58 AM 3/18/2004, Darin Oman wrote:
Yep, it looks like the cert is expired. Is there a way to quickly get a new one, or should I change the date on the machine to make it through the day? I could also go back to AG 1.x, but I'd hate to have to move backward.
Darin
On 3/18/2004 at 9:31 AM Robert Olson wrote:
Try bringing up the cert mgr and have a look at your default cert; I'm wondering if it has expired. (latest code has a lot more detail on cert failures, btw, so this sort of thing will be more obvious).
--bob
At 09:13 AM 3/18/2004, Darin Oman wrote:
Hello,
I'm suddenly unable to log into a venue client on my AG2 systems. I've tried 2 (they use the same passphrase and I think the same certificate) and I'm getting an "invalid passphrase" message on both. Can anyone help?
Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040318/0c340e67/attachment.htm>
