[AG-TECH] RAT issues
Robert Olson olson at mcs.anl.gov
Thu Mar 11 16:51:20 CST 2004
In particular, you need to ensure that UDP port 47000 is open. You'll also
need to enable incoming UDP to be able to see anything. (Unless windows'
firewall does the right thing with opening incoming ports when the outgoing
port sees traffic, tho that wouldn't work with the current vic).
--bob
At 03:18 PM 3/11/2004, Michael Miller wrote:
>Ron,
>Check the firewall available in windows.  It messes with RAT in nasty ways...
>MYK
>At 03:02 PM 3/11/2004, Ronald Crummett wrote:
>>Hello -
>>I am trying to setup AccessGrid on a new Dell Precision 360 workstation
>>PC and am having crazy audio issues.  When I try to connect to the grid I
>>have two VIC windows pop up but no RAT window (the same thing happens
>>under VRVS).  Then, when I try to turn the PC off I have to wait forever
>>because the PC is trying to shut down unresponsive programs, most of
>>which look to be RAT-related!  Has anyone seen something like this
>>before?  What do you think the problem may be?
>>-Ron Crummett
>>_________________________________________________________________
>>Get a FREE online computer virus scan from McAfee when you click here.
>>http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
>Thanx,
>Michael Miller
>System Engineer
>Visualization Technology Support
>Computing and Data Management
>National Center for Supercomputing Applications
>University of Illinois - UC
>217-649-0747
>"If you're clear in your vision and trust the people in your team with
>clear objectives, they will invariably do their best to achieve everything
>desired, and usually deliver everything you could have hoped for and even
>more." -Paul Debevec
More information about the ag-tech mailing list
