[AG-TECH] Multi-channel video capture
David Mcnabb
mcnabb at umd.edu
Thu Mar 4 08:59:04 CST 2004
On our WIN XP one-machine full nodes, the Winnov Videum 4400 has worked very well for us, though when we use it with the AGv2 SW we get two video streams when only one camera is attached. When used with the inSORS SW, the card works perfectly.
What do you mean by "extra work" when switching venues? Under AGv2 I get a new vic each time I change venues, so I must go in and turn on transmit as well as reset tiling to triple (the default single tiling is rarely useful. Can I change the defaults under AGv2 on XP?)
David McNabb
UMAGI
Univ. of Maryland
-----Original Message-----
From: "Osland, CD (Chris) " <C.D.Osland at rl.ac.uk>
To: AG Tech <ag-tech at mcs.anl.gov>
Date: Thu, 4 Mar 2004 13:56:52 -0000
Subject: [AG-TECH] Multi-channel video capture
My quest for efficient video capture of multiple channels via a
single card continues.
I was originally looking at the iTuner Spectra card (with 4 channels) but have found that the UK supplier has given up 'because of problems with support'. Many thanks for those who replied, especially Bob Riddle; from him I understand that use of the Spectra card increases the amount of hand-knitting that has to be done whne switching venues.
My next candidate is the Winnov Videum 4400 VO (or non-VO if I reckon I can use the audio interfaces to save on a sound card). Can the list tell me whether this would suffer in the same way (having to do extra work whenever you change venue)? I really want to increase automation, not add extra operator tasks.
Many thanks in advance for any views.
Cheers
Chris Osland
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> From: Bob Riddle [mailto:bdr at internet2.edu]
> Sent: 12 February 2004 17:45
> To: Osland, CD (Chris)
> Cc: AG Tech
> Subject: Re: [AG-TECH] hauppauge video problems
> yes - but as Mike said, every time I switch venues and vic(s)
> restart, I
> get the little window (for each instance of vic) that asks me
> to choose
> my video source. That doesn't annoy me, so I'm a happy
> Spectra8 card
> user (and I opened up a couple more PCI slots!)
> Osland, CD (Chris) wrote:
> >Just to check, Bob...
> >You say you're using the Spectra8 card - do I assume that you're
> >using it successfully!? Under XP? If so, that's the way I'm
> >going to go as well.
> >Cheers
> >Chris
> >Chris Osland
> Office tel: +44
> >(0) 1235 446565
> >1235 446459
> Grid room tel: +44
> >(0) 1235 445666
> Fax: +44
> >(0) 1235 445597
> use of the
> on it or show
> >it to anyone else,
> >>Sent: 11 February 2004 16:19
> >>To: Michael Miller
> >>Cc: Ti Leggett; Harold Micheal Goldman; AG Tech
> >>I actually use a Spectra8 card on our "loaner" AG - it has
> four video
> >>ports on it and works the way Michael describes. I've been
> >>trying to do
> >>the same thing with a 4-port Winnov card as well ... (you
> know, there
> >>are only so many PCI port in a one-box node!)
> >>Michael Miller wrote:
> >>>Just to add to what Ti said:
> >>>My experience has been that, depending on the driver, you
> >>can select
> >>>the WDM device in the configuration of multiple
> >>VideoProducers. When
> >>>vic starts up, one of the WDM cameras is automatically
> selected for
> >>>the first VideoProducer. Then you are given a series of
> dialogs to
> >>>choose a camera for each remaining VideoProducer. Again,
> >>whether you
> >>>get to choose another camera will depend on how the driver
> >>enumerates
> >>>the cameras. The QuickCam Pro 4000 does show you multiple
> cameras,
> >>>but it gives them all the same name. So, it can be confusing when
> >>>trying to choose a camera for the subsequent
> >>VideoProducers. If you
> >>>have two different cameras, the WDM drivers will assign names as
> >>>appropriate and it's much easier to decide which camera to
> >>choose. I
> >>>have an iBot firewire camera and a QuickCam Pro 4000 so I can see
> >>>which camera has become the default after the last
> session. If you
> >>>have two of the same camera and the driver doesn't assign each a
> >>>unique name, that's when you run into trouble.
> >>>HTH
> >>>Michael Miller
> >>>NCSA
> >>>At 05:36 PM 2/10/2004, Ti Leggett wrote:
> >>>>Actually the problem is this. Vic can only handle Video
> >>for Windows (VfW
> >>>>devices) which is an old driver style. vic can map the
> >>newer WDM drivers
> >>>>to a VfW device, but it can only do that for one device.
> >>Basically, if
> >>>>you have drivers that are VfW then all of them will be
> >>seen and usable
> >>>>in vic. If the drivers are WDM only, then vic will pick a
> >>device and map
> >>>>and that's it. Hauppage has stopped providing VfW drivers
> for their
> >>>>cards. Osprey, however, still provides VfW drivers for
> their cards.
> >>>>This driver issue is also why you can only have one web
> >>cam hooked up
> >>>>since, I'd say, all web cams provide only WDM drivers.
> >>>>Make more sense?
> >>>>On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
> >>>>>for what it's worth - I've been down this road and gave
> >>up - while
> >>>>this
> >>>>>is no problem on Linux, the driver for WinXP assumes
> >>that only one
> >>>>WinTV
> >>>>>card will be on the system. It cost less for a couple
> >>of Osprey100
> >>>>>cards than it did for the time I spent on trying to make
> >>this work.
> >>>>>sigh.
> >>>>>Harold Micheal Goldman wrote:
> >>>>>> Does anyone know of any way to get two hauppauge WinTv video
> >>>>capture cards to
> >>>>>>work at the same time in Windows XP. I am creating an
> >>Access Grid
> >>>>Node here at
> >>>>>>the University of Southern Mississippi for Collaboration for
> >>>>Genomic Research.
> >>>>>>I will also be setting up similar agn's at four othe
> >>universities
> >>>>here in the
> >>>>>>state. I had bought the two cards on the advice of a
> >>friend that
> >>>>admins a agn
> >>>>>>for the computer science dept here at usm, but we
> >>cannot get both
> >>>>cards to work
> >>>>>>under xp.
> >>>>>>Thank You
> >>>>>>Mike Goldman
> >>>>>>Bioinformatics Coordinator
> >>>>>>MFGN USM
> >>>Thanx,
> >>>Michael Miller
> >>>System Engineer
> >>>Visualization Technology Support
> >>>Computing and Data Management
> >>>National Center for Supercomputing Applications
> >>>University of Illinois - UC
> >>>217-649-0747
> >>>"If you're clear in your vision and trust the people in
> >>your team with
> >>>clear objectives, they will invariably do their best to achieve
> >>>everything desired, and usually deliver everything you could have
> >>>hoped for and even more." -Paul Debevec
> >>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
> >>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
> >>Business Phone: 734.913.4257 Fax Number: 734.913.4255
> >>"Opportunity is missed by most people because it is dressed
> >>in overalls and looks like work" Thomas Edison
