[AG-TECH] Fedora2 and Video sources
ULM AccessGrid accessgrid at ulm.edu
Tue Jun 29 14:59:18 CDT 2004
UPDATE
Just to let you know.  VIC and RAT both function fine.  I hear Audio and see
Video when I connect to a venue.  If I start up VIC manually then it sees
ALL the capture cards correctly.  It's only in the Node Management screen
that NONE of my capture cards show up.  This is true if I am running
NodeManager from either the capture computer or the display computer.  As a
test I ran the venue client on the capture box(the one I am working on) and
in the Node management window I still didn't see anything except X11.
It seems to me that AG2.2 is the only program that cannot see the video
cards.  VIC, xawtv both see them fine.
Adam Taylor
Computing Center
University of Louisiana at Monroe
  _____
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of ULM AccessGrid
Sent: Tuesday, June 29, 2004 11:08 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Fedora2 and Video sources
I have finally gotten AG2.2 to install and run on fedora2.  Everything seams
fine when running but there is one BIG problem.  NONE of my video cards show
up.  I only get X11 as a video source when trying to add a
VideoProducerService.  Is there anything special I need to do???  I used
xawtv to test and make sure the v4l is working, and the video comes through
just fine.  Is there something I am missing????
Also, I did have to force some things during the install to make it work.
Here is what I did.  Maybe this might be the problem.
Installed wxPythonGTK2.3 from source (build, installed, and copied libraries
to correct sources).  Build said it built correctly.
Installed RPM globus-accessgrid-2.4-1.  Rpm installed without any problems
Installed RPM AccessGrid-2.2-6.fc2 from
http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/RPMS/
            This threw up a dependency error for wxPythonGTK since the RPM
DB wasn't sure that it was installed.
            I over rode that with the command '-nodeps -force' when I
installed the RPM since I knew the library was already in place.
I tried to install just the RPMS from that site above but everytime I
started the VenueClient it crashed with a wxWindow error.  Only by building
the wxPython from source did the error go away.  Now the VenueClient runs
successfully.
Any ideas about my video cards not showing up???
Thanks
Adam Taylor
Computing Center
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040629/b935b581/attachment.htm>
More information about the ag-tech mailing list
