[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
Joseph joseph at cs.usyd.edu.au
Sun Jun 20 21:31:59 CDT 2004
Hi
> I resorted to "alien" again in the interests of having a running node now
> that we've got most of our equipment, but I am still trying to think
> about
> the packaging.
Just to know : is there something special to do after having installed
AG2.2 to have it work properly ?
I say so because I have one AG2.2 installed but it doesn't work. I have
managed to request a certificat with success but otherwise, when in a
room, I have nothing which pops up (for the video and/or the sound for
example) and I don't manage to run "/Preferences/Manage My Node...". After
having specified my node service URL it says "Can not open node management
at https://localhost:11000/NodeService". Do you have any clue ?
BTW, did you have to install some other package to have AG2.2 running ? On
my side I have installed xawtv and the sound is working...
> In my case, until I work out what the heck the "debian way"
> is supposed to be to make such settings,I just manually
> source the below into the shell before launching
> any globus/accessgrid command.
Most of the time the "Debian way" I have found is to add the requested
lines in /etc/bash.bashrc so they are loaded each time you open a terminal.
> #!/bin/bash
> #export GPT_LOCATION=/usr/lib/gpt
> export GLOBUS_LOCATION=/usr/lib/globus
> source /usr/lib/globus/etc/globus-user-env.sh
I'm quite surprise you need to do so. In fact globus isn't needed to run
AccessGrid, or at least you just have to install /usr/lib/gpt and nothing
in /usr/lib/globus. Did you run gpt-postinstall and gpt-verify after
installing gpt ? Because I did so and I have no more trouble related to
globus-user-env.sh .
Cheers,
  Joseph
More information about the ag-tech mailing list
