Fwd: Re: [AG-TECH] Fedora 2
Todd Zimmerman
toddz at sfu.ca
Thu Jun 17 17:25:16 CDT 2004
Excellent!
Thanks Sugree et. al. for all of the _extremely_ helpful info and the
RPM's!!
You saved me from a world of pain ;-)
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Michael Miller wrote:
> Here are Sugree's instructions I used. Be sure to request a service
> cert for your particular machine before firing up a VenueServer. I had
> trouble using a service cert from another machine.
> Thanx much to Sugree for setting this up!
> Michael Miller
>> From: "Sugree Phatanapherom" <sugree at hpcnc.cpe.ku.ac.th>
>> To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
>> Subject: Re: [AG-TECH] Fedora 2
>> Date: Thu, 17 Jun 2004 09:39:10 +0700
>> Hi,
>> What you want to do is just add 3 lines in /etc/yum.conf.
>> --> cut <--
>> [accessgrid]
>> name=AccessGrid
>> baseurl=http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2
>> --> cut <--
>> Next time you run YUM, it will download all info about accessgrid so
>> you can
>> simply install it as below:
>> # yum groupinstall agtk
> I stopped here and then ran the venue client to request/install my cert
> I haven't tried the rest of this...
>> Note that if you want to create a yum repository, yum-arch command can
>> help
>> you. Just change working directory to where you keep all rpms and
>> yumgroup.xml (if available) and then run "yum-arch ." to generate
>> headers/*.
>> Hope this helps,
>> > I love YUM! But I don't know it well enough to know where to put this
>> > stuff. please let me know what file to edit.
>> > Thanx
>> > Michael Miller
>> > NCSA
>> > At 10:09 AM 6/16/2004, you wrote:
>> > >[accessgrid]
>> > >name=Access Grid
>> > >baseurl=http://osl.cpe.ku.ac.th/pub/fedora/linux/core/$releasever
>> > >Then simply run:
>> > >Good luck,
>> > Thanx,
>> > Michael Miller
>> > System Engineer
>> > Visualization Technology Support
>> > Computing and Data Management
>> > National Center for Supercomputing Applications
>> > University of Illinois - UC
>> > 217-649-0747
>> > "If you're clear in your vision and trust the people in your team with
>> > clear objectives, they will invariably do their best to achieve
>> everything
>> > desired, and usually deliver everything you could have hoped for and
>> even
>> > more." -Paul Debevec
> Thanx,
> Michael Miller
> System Engineer
> 217-649-0747
> everything desired, and usually deliver everything you could have hoped
> for and even more." -Paul Debevec
