[AG-TECH] All-Windows AG nodes?
Joshua M. Brown
jmb10 at uark.edu
Wed Jun 16 14:18:51 CDT 2004
David E. Bernholdt [bek] 574-3147 wrote:
>Since Windows PIGs work okay, I assume a multi-machine all-Windows AG
>node configuration (as opposed to Windows for display and Linux for
>capture) works okay, but can anyone confirm that they're actually
>using such a setup? Are there any problems with multiple Hauppague
>video capture cards under Windows? Would anyone have reservations
>about going with such a setup?
There is a multi-machine node running all Windows (XP, i think. Do not
hold me to that) in Little Rock at UAMS. i will try to find the correct
contact information for you if they do not reply to this (they are very
responsive normally). It sounds like it works smoothly from i've heard.
Josh
>Thanks
>David E. Bernholdt | Email: bernholdtde at ornl.gov
>Oak Ridge National Laboratory | Phone: +1 (865) 574 3147
>http://www.csm.ornl.gov/~bernhold/ | Fax: +1 (865) 576 5491
