[AG-TECH] venue client problems
John I Quebedeaux Jr
johnq at lsu.edu
Tue Jul 27 14:26:59 CDT 2004
From the 2.1.2 perspective:
Earlier this morning, had no trouble with the venue server (9a-12p
CDT). Then later, for a 1pm meeting - (along with Adam) we had trouble.
I was already in the venue... which remained just fine. I didn't get
kicked (that was a surprise) out. I'm running 2.1.2 on this node (mix
WinXP and Linux 8.0).
Our other sites couldn't join via the client and manually joined in so
we could get the meeting going. I reaaly need to remember to crank up
our venue server...
-John Q.
John I. Quebedeaux, Jr.
Louisiana State University
Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339 Johnston
Hall
e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu &
http://cct.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On Jul 26, 2004, at 9:47 PM, Markus Buchhorn wrote:
> Hi all at ag-dev
> On a 2.2 node (venue client on Windows) I can enter and move around
> the APAG venue server (2.1.2 from memory?) fine, but have all sorts of
> problems entering and moving around the ANL venue server. Typical
> behaviour is
> 1. I get kicked off,
> 2. I get invited to reconnect
> 3. I get kicked off before I have fully reconnected
> 4. Repeat 2-3 at ever faster rate.
> Occassionally I get in and can stay in, on the main Lobby venue. If I
> try and enter the Institutional Lobby though it takes a looooong time,
> and then eventually enters the main Lobby again - not letting me drop
> down to lower venues at all. Then after all a while I get kicked off
> (see above :-) ).
> Also: There doesn't seem to be any way to say to the venue client to
> cancel an attempt to enter a venue. So if there's any problems getting
> into a venue, it effectively hangs the venue client. Timeouts might
> help, but there's too many places where some delays might occur. It'd
> be nice if the venue client could provide fairly detailed
> state-information as to where it is up to when changing venues
> ('killing/ed rat, killing/ed vic, entering/ed venue, starting/ed vic,
> starting/ed rat, things should be normal now, ...' :-) ).
> Is there any plan for a minor update to 2.2 to fix these things (if
> you know what is causing them), or is 2.3 close? scglobal is looming.
> Cheers,
> Markus
> Markus Buchhorn, ANU Internet Futures Group, |Ph: +61 2 61258810
> Markus.Buchhorn at anu.edu.au, mail: Bldg #108 CS&IT |Fx: +61 2 61259805
> The Australian National University, Canberra 0200 |Mob: 0417 281429
