[AG-TECH] Cert probs . . MORE
Chris Willing
willing at itee.uq.edu.au
Fri Jul 23 21:18:06 CDT 2004
On Sat, 2004-07-24 at 11:44, Chris Willing wrote:
> Importing through VenueClient is easiest, if you can make it work.
> Other methods are:
> 1. run AGServiceManager.py from command line. If no certificate proxy is
> active, you'll be invited to enter passphrase/lifetime/keysize so that
> it can run. Note that you may have to destroy any previous proxies using
> grid-proxy-destroy command (before running AGServiceManager.py).
> 2. run grid-proxy-init from command line. Since globus certs are no
> longer used, it doesn't know where to find some files so you'll have to
> provide -cert <certfile> and -key <keyfile> options to it.
And if you mean how to import the .pem file itself, run the certmgr.py
command. It gives a prompt "(ID mode) >" at which you can give it
various instructions; try ? for help. More specifically, you could
enter:
import newcert.pem
You can list existing certs with:
list
and delete exisiting certs with:
delete n
(where n is a cert number as provided by the "list" command)
chris
Chris Willing Phone: +61 7 3365 8350
University of Queensland Email: willing at itee.uq.edu.au
St Lucia, QLD 4072, Australia
