[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
Fred Dech
fdech at uchicago.edu
Fri Jul 16 15:35:17 CDT 2004
hey Eric.
that works for both VideoProducerService.py & VideoService.py. i noticed
that the 'status' field doesn't get preserved upon restarts, though. ;^)
i have 1 bigger and 1 smaller problem that i don't have a clue how to
solve because i don't understand the underlying code At All in, say,
AGServiceManager.py.
bigger:
regardless of how the node services come up (TV or not TV) in my
ServiceManager, i still have to set my VideoService VICs from Composite1 to
S-Video every time i change venues.
i have a hunch that this error message is related to that...
INFO:ServiceManager:Using services dir: /home/aguser/.AccessGrid/local_services
INFO:ServiceManager:__DiscoverResources
config: invalid value for input: (null)
valid choices for "input": "Television", "Composite1", "S-Video", "Composite3"
smaller:
same issue as above with VideoProducerServices, plus i cannot see my
video streams in the VIC.
the obvious solution is to use VideoServices rather than VideoProducerServices.
does VideoServices add to the amount of data being received, or are those
extra sub VICS just displaying from the same streams as the master VIC?
thanks.
--fred
On Fri, Jul 16, 2004 at 01:07PM, Eric Olson said:
> Hi Fred and Doug,
> I checked in a small change to VideoService.py and VideoProducerService.py
> in cvs that should fix the problem causing the video port settings getting
> reset to the default port all the time (Bug #1067).
> Let me know if it fixes that problem for you once you're able to test
> it.
> Eric
> On Fri, 16 Jul 2004, Fred Dech wrote:
> > hi Doug.
> > i applied your patch to VideoService.py.
> > at first i thought that it changed the character of things; i'd been using
> > videoProducerServices rather than VideoServices. but i've now double and
> > triple checked.
> > i believe you're right when you said:
> > > Notice the "invalid value for input: (null)" stderr output from
> > > /usr/bin/v4lctl. I think the corresponding V4L2 driver (the bttv driver?)
> > > needs some minor mods in the source code to indicate the inputs that
> > > particular model of Osprey capture card has, currently all the inputs on
> > > that card don't have a name.
> > before the patch and after the patch, i get the same output:
> > INFO:ServiceManager:Service VideoService successfully started
> > INFO:ServiceManager:Setting service configuration
> > INFO:ServiceManager:Assigning resource to service: /dev/video0
> > INFO:Toolkit:VideoService.SetResource : /dev/video0
> > INFO:ServiceManager:AGServiceManager.AddService
> > INFO:ServiceManager:AddService: VideoService v 2.210000 u https://sucag1.uchicago.edu:54513/packages/VideoService.zip
> > INFO:ServiceManager:resourceToAssign: /dev/video1
> > INFO:ServiceManager:Searching for local service package
> > INFO:ServiceManager:Found local service VideoService, v2
> > INFO:ServiceManager:Running Service; options: /usr/bin/python2 ['/home/aguser/.AccessGrid/local_services/VideoService/VideoService.py', 59926]
> > my new Node Service config file has:
> > [service2]
> > packagename = VideoService.zip
> > resource = resource2
> > serviceconfig = serviceconfig2
> > [serviceconfig2]
> > encoding = h261
> > mutesources = Off
> > streamname = Video
> > framerate = 24
> > standard = NTSC
> > bandwidth = 800
> > transmitonstartup = On
> > quality = 75
> > port = S-Video
> > but the VideoSerices instantiated upon startup of VenueClient still default
> > to Television for input.
> > i bet this is some weird driver issue as you implied.
> > using VideoService i still need to swap from Composite1 to S-Video each
> > time i enter a venue. but at least i can see my video. it doesn't show up
> > on the Master VIC, but the two VideService Sub VICs do display it. and
> > other clients can still see me.
> > i'm going to take a closer look at bttv and try and figure out why those
> > error messages are being produced whenever the VenueClient starts up.
> > thanks.
> > --fred
