[AG-TECH] problems starting AGNodeService ...
Darran Edmundson
darran.edmundson at anu.edu.au
Mon Jul 5 22:08:30 CDT 2004
I'm having problems with AGTk2.2 in that the VenueClient
is hanging on startup. You know, when the progress bar
zips across to about 75% complete and then pauses
indefinitely. (This under WinXP.)
Trying things manually, AGServiceManager seems to start
up fine but then I get the following with AGNodeService:
C:\Program Files\AGTk-2.2\bin>python AGNodeService.py
<Fault SOAP-ENV:Client: Method Not Found: ServiceManager:IsValid :
exceptions.Ke
yError 'ServiceManager' <traceback object at 0x01281CD8>>
Error loading default node configuration
Has anyone else observed this? Same problem whether
or not ServiceManagers are running on the other two
machines in the node.
Cheers,
Darran.
