[AG-TECH] Error occurred during certificate import
Robert Olson
olson at mcs.anl.gov
Fri Jan 30 16:19:52 CST 2004
At 04:10 PM 1/30/2004, Carter, Tameka wrote:
>Hey,
>A friend of mine had the same problem. We tried deleting the certrepo
>directory and importing again. I was then told the key was not with the
>certificate. We then tried to request another certificate 4-5 days
>ago. We have not gotten it yet.
If you delete teh certrepo after doing a request of a certificate, you will
indeed get that error - deleting the certrepo directory will delete the
private key for the requested certificate, leaving it useless.
>On another note, is it the case that any certificate works? I have a DOE
>science grid certificate I have been wondering about.
Yup, you can use that. You need to import the DOE science grid CA certs
first, then you can import the DOE cert itself.
--bob
