[AG-TECH] How to start VideoProducerService and AudioService in AG 2.1.1
Vu Quang Minh
vuminh at mlab.t.u-tokyo.ac.jp
Thu Jan 22 02:01:35 CST 2004
Hi all,
I am trying to start VideoProducerService and AudioService
for my node at The University of Tokyo. I have followed the
instructions here:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/RoomBasedNode-HowTo/Room-BasedNode-HOWTO.htm#_Toc42180368
Step 1:
Run AGServiceManager.py on each machine
Double click AGServiceManager.py in the Windows machine
Run AGServiceManager.py -d for the audio machine and
video capture machine (Redhat 9.0 machines)
Run AGNodeService.py on the display Windows machine
(double click the file)
Step 2:
Run the NodeManagement.py on the display Windows machine
Step 3:
At the NodeManagement.py GUI on the display machine I select
"ServiceManager -> Add" 3 times and set the hostnames and ports
as follow:
Hostname: <Display machine's IP>; Port: 12000
Hostname: <Audio machine's IP>; Port: 12000
Hostname: <Capture machine's IP>; Port: 12000
Step 4:
"Service -> Add" for 3 ServiceManagers and set the services
VideoConsumerService, Audio service, VideoProducerService
for them respectively.
Step 5:
Configure the Video Producer Service at the NodeManagement.py GUI
Step 6:
Store the Node configuration, but I can not get the status "started"
for any Service as stated in the instruction page.
Step 7:
Run the VenueClient.py and go to the default Venue at
https://vv2.mcs.anl.gov:9000/Venues/default
Then I can get video stream from other nodes but all of my services
(VideoConsumerService, VideoProducerService and AudioConsumerService)
still did not change to "Started" status.
Are there any wrong with the above setting?
Vu Quang Minh <vuminh at mlab.t.u-tokyo.ac.jp>
