[AG-TECH] New Camera - Got it!
Jennifer Teig von Hoffman
jtvh at bu.edu
Wed Jan 21 15:37:55 CST 2004
There's also a tutorial on debugging multicast networking on the AG
Training Project web site, http://webct.ncsa.uiuc.edu:8900/public/AGIB/
(free registration required). It's written primarily for node operators,
but may be valuable to some networking staff as well.
- Jennifer
Thomas D. Uram wrote:
> As a firs step, you can look at two tools: the Internet2 Detective (
> http://detective.internet2.edu ) will tell you whether your network has
> multicast enabled; the multicast beacon (
> http://dast.nlanr.net/Projects/Beacon ) will tell you the quality of
> your connectivity to other sites running beacon clients.
> Tom
> Ronald Crummett wrote:
>> Hello -
>> Well, I somehow figured out what was going on with my camera and it is
>> working fine now. Thanks for all the help and suggestions; it gave me
>> a lot to start off of and gave me the courage to go poking around a
>> little more.
>> If anyone has any advice for me on how to verify and configure
>> multicast now, I'd greatly appreciate that.
>> -Ron Crummett
>>> From: "Ronald Crummett" <ron_crummett at hotmail.com>
>>> To: derksl at unm.edu, ag-tech at mcs.anl.gov
>>> CC: bigdaddychuck at juno.com
>>> Subject: Re: [AG-TECH] New Camera
>>> Date: Wed, 21 Jan 2004 12:33:44 -0700
>>> When I use the camera with other applications I can see everything
>>> fine. I have tried adjusting the configuration as mentioned, but it
>>> doesn't help all that much. I can almost see myself in the video
>>> now, but still not nearly as good as when I am using other programs.
>>> Any further suggestions? Thanks again!
>>>> From: "Lee Derks" <derksl at unm.edu>
>>>> To: "Ronald Crummett" <ron_crummett at hotmail.com>, <ag-tech at mcs.anl.gov>
>>>> CC: <bigdaddychuck at juno.com>
>>>> Date: Tue, 20 Jan 2004 13:34:38 -0700
>>>> Hello,
>>>> Are you able to see the video image clearly in other
>>>> applications, such
>>>> as programs that came with the video camera? You may want to check the
>>>> encoder you are using in the VIC. One of the preferred encoder's is
>>>> h261.
>>>> Also, you may want to go through the steps of "configure on
>>>> transmit." To
>>>> configure on transmit, click on "options" --> "configure on
>>>> transmit", click
>>>> on "release" and then "transmit." Make sure that the resolution is
>>>> set to
>>>> the appropriate size, click "ok" and then check the brightness,
>>>> contrast,
>>>> saturation, and hue settings.
>>>> Good luck
>>>> Lee Derks
>>>> ----- Original Message -----
>>>> To: <ag-tech at mcs.anl.gov>
>>>> Cc: <bigdaddychuck at juno.com>
>>>> Sent: Tuesday, January 20, 2004 10:10 AM
>>>> Subject: [AG-TECH] New Camera
>>>> > I have been working on setting up a laptop node on my Compaq Presario
>>>> 2100.
>>>> > Initially I was using a standard digital camera operating in a PC
>>>> camera
>>>> > mode. I recently purchased a real PC camera, a Veo Mobile
>>>> Camera. But
>>>> when
>>>> > I try connecting to the grid using this camera, I don't get a
>>>> clear image
>>>> at
>>>> > all - in fact, all I really see is a red display with a few other
>>>> colors
>>>> > moving on occasion. What would cause this, and what would I need
>>>> to do to
>>>> > fix it?
>>>> > In other problems, I cannot see anyone else when I do connect to the
>>>> > AccessGrid. I have been told that this is most likely a multicast
>>>> problem
>>>> > and that sounds reasonable, but I still don't know how to verify
>>>> that or
>>>> > what can be done about that. Any ideas? Your help is greatly
>>>> appreciated
>>>> > and will continue to be greatly appreciated.
>>>> > -Ron Crummett
>>>> > _________________________________________________________________
>>>> > Check out the coupons and bargains on MSN Offers!
>>>> > http://shopping.msn.com/softcontent/softcontent.aspx?scmId=1418
>> Let the new MSN Premium Internet Software make the most of your
>> high-speed experience.
>> http://join.msn.com/?pgmarket=en-us&page=byoa/prem&ST=1
