[AG-TECH] New Camera
Ronald Crummett
ron_crummett at hotmail.com
Wed Jan 21 13:33:44 CST 2004
When I use the camera with other applications I can see everything fine. I
have tried adjusting the configuration as mentioned, but it doesn't help all
that much. I can almost see myself in the video now, but still not nearly
as good as when I am using other programs. Any further suggestions? Thanks
again!
>From: "Lee Derks" <derksl at unm.edu>
>To: "Ronald Crummett" <ron_crummett at hotmail.com>, <ag-tech at mcs.anl.gov>
>CC: <bigdaddychuck at juno.com>
>Subject: Re: [AG-TECH] New Camera
>Date: Tue, 20 Jan 2004 13:34:38 -0700
>Hello,
> Are you able to see the video image clearly in other applications,
>such
>as programs that came with the video camera? You may want to check the
>encoder you are using in the VIC. One of the preferred encoder's is h261.
>Also, you may want to go through the steps of "configure on transmit." To
>configure on transmit, click on "options" --> "configure on transmit",
>click
>on "release" and then "transmit." Make sure that the resolution is set to
>the appropriate size, click "ok" and then check the brightness, contrast,
>saturation, and hue settings.
>Good luck
>Lee Derks
>----- Original Message -----
>From: "Ronald Crummett" <ron_crummett at hotmail.com>
>To: <ag-tech at mcs.anl.gov>
>Cc: <bigdaddychuck at juno.com>
>Sent: Tuesday, January 20, 2004 10:10 AM
>Subject: [AG-TECH] New Camera
> > I have been working on setting up a laptop node on my Compaq Presario
>2100.
> > Initially I was using a standard digital camera operating in a PC camera
> > mode. I recently purchased a real PC camera, a Veo Mobile Camera. But
>when
> > I try connecting to the grid using this camera, I don't get a clear
>image
>at
> > all - in fact, all I really see is a red display with a few other colors
> > moving on occasion. What would cause this, and what would I need to do
>to
> > fix it?
> > In other problems, I cannot see anyone else when I do connect to the
> > AccessGrid. I have been told that this is most likely a multicast
>problem
> > and that sounds reasonable, but I still don't know how to verify that or
> > what can be done about that. Any ideas? Your help is greatly
>appreciated
> > and will continue to be greatly appreciated.
> > -Ron Crummett
> > _________________________________________________________________
> > Check out the coupons and bargains on MSN Offers!
> > http://shopping.msn.com/softcontent/softcontent.aspx?scmId=1418
