[AG-TECH] Disappearing venue definitions?
Randy Groves
randy.groves at boeing.com
Mon Jan 12 19:31:22 CST 2004
Has anyone else had this happen? I've been running an AG 2.x Venue server
for some time now. I left it up over the holidays, but didn't actually
check on whether it was responsive or not. When I returned, I just assumed
that it had gone to sleep, although it was still running (the BridgeServer
was also up), so I restarted both.
Lo and behold, when I attempted to connect to my venues, I find that they
had all disappeared! The venue server was back to it's default initial
state. There was no 'backup' in the VenueServer.dat.bak file - it was
identical to the main .dat file.
This has happened before, and those times, I figured it was something that
I had done in fiddling with the configuration. But definitely NOT this
time. There is nothing that is obvious in the logs.
While my venue server is not enormous, re-entering is not a huge pain, but
a pain, nevertheless.
But this points up a fairly significant hole in the venue server workings -
there is no way (that I know of) to back up the server, and if that was
available, of restoring it if it is trashed. I presume that if a version
of the .dat file was available, it would be possible to manually restore
the server, but I have not encountered the instructions for this process,
if it exists.
Oh, and BTW - I'd check Bugzilla for something like this, but it seems to
be not answering its calls at the moment...
-randy
