[AG-TECH] Working wxMozilla based SharedBrowser
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Dec 16 22:17:27 CST 2004
David Gwynne wrote:
>> Ivan R. Judson wrote:
>> Is this cross platform? ie, will it work on Mac OS or Windows?
> This version of the shared browser depends on the wxMozilla widget, not on
> any platform specific functionality. If you can get the wxMozilla widget
> working then the Shared Browser in turn should just work.
I should add, that my initial announcement was a little misleading where I
mentioned that there is no need to download any RPM, that comment was
suppose to be aimed at people that had previously tried using the
broken/experimental wxMozilla based Shared Browser that comes with the
Fedora AccessGrid 2.3 RPMs.
Cheers,
Doug
>>>-----Original Message-----
>>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>>Behalf Of Douglas Kosovic
>>>Sent: Wednesday, December 15, 2004 10:52 PM
>>>To: ag-tech at mcs.anl.gov
>>>Subject: [AG-TECH] Working wxMozilla based SharedBrowser
>>>Hi,
>>>A wxMozilla based SharedBrowser that now works can be found at:
>>> http://www.itee.uq.edu.au/~agn/ag_fedora/
>>>There is no need to download any RPM, just the small SharedBrowser.agpkg
>>>file.
>>>David Gwynne, here at UQ-ITEE came up with a workaround for the
>>>wxMozilla-python bug which was causing the browser to crash when remote
>>>sites changed URLs.
>>>Doug
