[AG-TECH] An onslaught of questions
Frank Sweetser
fs at WPI.EDU
Fri Apr 23 10:37:18 CDT 2004
On Fri, Apr 23, 2004 at 08:23:24AM -0700, Randy Groves wrote:
> If you are using AG2, might I make a suggestion? Create a node setup that
> is audio only (you could even make this your default), in addition to your
> normal setup. Use the audio-only setup to navigate to your chosen
> venue. Then change to your normal setup. That way you avoid the video
> streams on the way in.
There is also an option to temporarily disable audio and video in the
Preferences menu in the venue client.
Frank Sweetser fs at wpi.edu
WPI Network Engineer
GPG fingerprint = 6174 1257 129E 0D21 D8D4 E8A3 8E39 29E3 E2E8 8CEC
