[AG-TECH] Soundblaster Live! input routed to output?
Dwight D.McKay
mckay at purdue.edu
Wed Apr 7 12:10:30 CDT 2004
Folks,
We're experiencing a strange problem with a new room node. The audio
machine is using a new, soundblaster live! card that seems to route the
analog line input to the analog line output no matter what we do. We've
tried both the RedHat 9 sounds drivers and ALSA.
On an earlier model Soundblaster (128?), we needed to use emu-dspmgr
and change the routing on the card to avoid this problem. On this card,
the similar routing trick doesn't seem to work.
Has anyone seen this and found a solution?
Dwight D. McKay, Technical Architect
Envision Center for Data Perceptualization, Office of the VP for IT,
Purdue University
mckay at purdue.edu / 765.494.4481 [VOICE] / 765.496.7264 [FAX] / STEW
B31
