[AG-TECH] projector control ?
Steve Slocombe
s-slocombe at northwestern.edu
Mon Sep 22 13:54:12 CDT 2003
As Luc pointed out, getting the serial commands can be a bit of a bear. We had to sign a nondisclosure with
NEC when we asked for the control codes for the epson 715C. Personally I think its ludricous that
manufacturers keep that information private.
Once we got them I put them in a small executable with director and now all 3 projectors power up/power down
and go to the correct input. Needless to say much more convenient.
S.
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Luc Renambot
> Sent: Friday, September 19, 2003 6:17 pm
> To: 'Andrew Daviel'; 'Ag-Tech'
> Subject: RE: [AG-TECH] projector control ?
> The problem is to get the commands for the serial port.
> On cheap projectors, usualy the manufacturer doesn't give
> you the commands.
> When we built a tiled-display and an AG node in Amsterdam,
> Philips gave us the commands going through the mouse port of
> the projector. Writing a small library in C, you can then
> wrap it in Python and control your projectors from a small
> script or a web page (with Apache webserver, with python
> module). It's so much easier to use a web browser than 20 ir
> remote controls.
> Luc.
> ] -----Original Message-----
> ] From: owner-ag-tech at mcs.anl.gov
> ] [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Andrew
> Daviel ] Sent: Friday, September 19, 2003 5:22 PM ] To:
> Ag-Tech ] Subject: [AG-TECH] projector control ? ]
> ] I wondered if anyone had worked on projector control over
> RS232 ? ] (or for that matter, camera control) ]
> ] We have a couple of Hitachi SXGA projectors and a Sony XGA.
> ] It would be nice to have an application which could power
> ] them all up and select the correct inputs when starting AG.
> ] (we use other inputs for a Polycom Viewstation, digital
> ] presnter, table laptop etc.)
> ] I suspect I'd have to get USB to serial adapters as there's
> ] only one serial port and I'm using it for Sony EVI-D camera
> ] control (the software I got is quite complex and uses a Java
> ] client for interactive control, while what I'd like is to
> ] script "turn on and point at the table with zoom factor 1.3") ]
> ] ... I gather there are commercial units which will do all
> ] this and dim the room lights too..
> ] Andrew Daviel, TRIUMF, Canada
> ] Tel. +1 (604) 222-7376
> ] security at triumf.ca
