[AG-TECH] MOO communication ports
Robert Olson
olson at mcs.anl.gov
Mon Sep 22 11:04:18 CDT 2003
moo doesn't use incoming to the clinet; however, port 7777 may be blocked
due to its use also in filesharing apps. There is a moo proxy server
running on 7779 that you can try using.
--bob
On Mon, 22 Sep 2003, Brian d'Auriol wrote:
> A local port scan might help, are you on windows? if so, I use the
> freeware active ports found
> on http://www.ntutility.com This software reports on the local processes
> which have opened ports. It is easy to download and install. Hope this
> helps.
> Brian
> (Computer Sci. UTEP)
> On Mon, 22 Sep 2003, Alson Been wrote:
> > Date: Mon, 22 Sep 2003 11:20:15 -0400
> > From: Alson Been <beena at cookman.edu>
> > To: Ag-Tech <ag-tech at mcs.anl.gov>
> > Subject: [AG-TECH] MOO communication ports
> > Hello all,
> > Does anyone know if there is an in bound port that is used by the MOO
> > client? I know port 7777 is out bound which is allowed, but for some
> > reason I am not able to connect going through a PIX firewall and doing
> > static NAT. Is there a way to identify from the client which ports are
> > being used? Any thought on this?
> > Thanks
> > _______________________________________
> > Alson Been
> > Bethune-Cookman College
> > 640 Dr. Mary McLeod Bethune Boulevard
> > Faith Hall Annex A02
> > Daytona Beach, FL 32114-3099
> > Phone: 386-481-2336
> > Fax: 386-481-2023
> > Suncom: 8-378-2336
> > E-mail: beena at cookman.edu
> > Check out our home page: www.cookman.edu <http://www.cookman.edu/>
