[AG-TECH] 2.1.1b single machine no video capture
Randy Groves
randy.groves at boeing.com
Mon Sep 15 15:17:17 CDT 2003
There is a bug (hopefully fixed) where the path to the vic executable
doesn't get set when you manually add a VideoProducer service. You need to
'Configure' the VideoProducer service(s) and add the full path (probably
something like 'c:\\program files\Access Grid Toolkit\bin' before the 'vic'
string that is there. Obviously, this will vary depending upon where you
installed the AG Toolkit, and you also need to remember to add the '\'
between the end of that string and 'vic'.
Then re-enter the venue, and you should get your streams.
-randy
At 03:38 PM 9/15/2003 -0400, James Miller wrote:
>I have the AGTK2.1.1b installed and working relatively well except for the
>fact that I do not see my video feed in the vic window. I have added the
>VideoProducer service using M$ WDM Image Capture and the port is set to
>external-in. The camera is a simple USB QuickCam that does work on this
>machine using other capture software. Can someone point me in the proper
>direction?
>Thanks,
>Jim Miller
>PSC
