[AG-TECH] AG2.1.1b multi-machine node problems
Eric Olson
eolson at mcs.anl.gov
Mon Sep 8 09:38:13 CDT 2003
Hi Mike,
Ivan and I didn't have any problems the TVS this morning, but let us know
if it's still not working for you.
And on linux,
Thanks for noticing the /tmp/local_services directory. We're moving the
local services (cache) to be in the user's ~/.AccessGrid/local_services
directory, but it looks like it didn't get built into the last rpm so
we'll get that fixed. Moving it to the user's directory will avoid the
past problems with the tmp directory.
Thanks again,
Eric
On Mon, 8 Sep 2003, Michael Daw wrote:
> Thanks, Eric.
> As well as these steps, I also had to add the directory /tmp/local_services
> on my video capture machine. But, I think we're there now (the ANL server is
> down, I think, stopping a fully successful test!).
> --Mike
> > -----Original Message-----
> > From: Eric Olson [mailto:eolson at mcs.anl.gov]
> > Sent: 05 September 2003 23:37
> > To: Ivan R. Judson
> > Cc: 'Michael Daw'; 'George Estes'; 'ag Tech'
> > Subject: RE: [AG-TECH] AG2.1.1b multi-machine node problems
> > I neglected to mention one more thing for running as another user:
> > Make sure the following directory exists:
> > C:/Documents and Settings/<user>/Application
> > Data/AccessGrid/local_services
> > Eric
> > On Fri, 5 Sep 2003, Eric Olson wrote:
> > > If you want to install as one user and run as another:
> > > In addition to rerunning globus config, there are three items
> > that are not
> > > installed into the user's personal directory. We are working on fixing
> > > this, but here are the three items:
> > > AGServiceManager.cfg
> > > AGNodeService.cfg
> > > nodeConfig (folder)
> > > You need to copy them and then change the user name in two config files.
> > > 1)
> > > Copy them from:
> > > C:\Documents and Settings\Administrator\Application Data\AccessGrid
> > > To:
> > > C:\Documents and Settings\<user>\Application Data\AccessGrid
> > > 2)
> > > Open AGServiceManager.cfg and AGNodeService.cfg with notepad
> > and change
> > > "Administrator" (or whichever user installed it) to your username.
> > > This should fix problems with services not starting (audio and
> > video). To
> > > verify this has worked, you can restart the venueclient, go to
> > > Preferences, Manage My Node, and you should see a service
> > manager listed.
> > > Eric
> > > On Fri, 5 Sep 2003, Ivan R. Judson wrote:
> > > > Mike,
> > > > Another solution that has worked for us is to run the globus
> > configuration
> > > > wizard as the user using the AGTk (admin or not). After
> > having installed as
> > > > the admin, this will initialize the user environment --
> > making it possible
> > > > to use the toolkit as a non-admin user.
> > > > --Ivan
> > > > > From: owner-ag-tech at mcs.anl.gov
> > > > > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Daw
> > > > > Sent: Friday, September 05, 2003 11:02 AM
> > > > > To: George Estes
> > > > > Cc: ag Tech
> > > > > Thanks, George. I did try this when I encountered the
> > > > > problem. I've just tried it again to make sure, but it
> > > > > doesn't work for me!
> > [mailto:owner-ag-tech at mcs.anl.gov]On
> > > > > > Behalf Of George Estes
> > > > > > Sent: 05 September 2003 15:10
> > > > > > To: Michael Daw
> > > > > > Cc: ag Tech
> > > > > > Subject: Re: [AG-TECH] AG2.1.1b multi-machine node problems
> > > > > > Mike,
> > > > > > Sounds like you're encountering the install as
> > > > > administrator, run
> > > > > > as user problem. If this is on a windows machine, you're
> > > > > having the
> > > > > > same problem I had. This is what I did to make it work,
> > install as
> > > > > > user with administrator privileges and change the "start
> > > > > in" path in
> > > > > > the venue client shortcut to C:\Program Files\Access Grid
> > > > > Toolkit\bin.
> > > > > > The Node Setup Wizard was then able to find the services.
> > > > > > Hope this works for you.
> > > > > > George
> > > > > > At 11:10 AM 9/5/2003 +0100, you wrote:
> > > > > > >Has anyone found any problems configuring a AG2.1.1
> > multi-machine
> > > > > > >node?
> > > > > > >I get to the stage where I can add the ServiceManagers,
> > > > > but I can't
> > > > > > >add associated Services (the dialog is blank). I've
> > tried the Node
> > > > > > Setup Wizard
> > > > > > >and this fails too (when I press 'Finish', it flags an error and
> > > > > > >sends an automated log to ANL).
> > > > > > >Alternatively, has anyone done this successfully? Or -
> > > > > best of all -
> > > > > > >has anyone encountered this problem and overcome it?
> > > > > > >Frustratingly enough, I managed to do this under AG2.0,
> > > > > but there was
> > > > > > >the (now fixed) bug of no support for PAL. So, something's
> > > > > changed...
> > > > > > >--Mike
> > > > > > >_______________________________________________________
> > > > > > >Michael Daw, e-Science Consultant
> > > > > > >SVE Group (Supercomputing, Visualization and e-Science)
> > > > > > >Manchester Computing, Kilburn Building,
> > > > > > >University of Manchester, Manchester M13 9PL, UK
> > > > > > >Tel: +44 (0)161 275 7026
> > > > > > >Fax: +44 (0)161 275 6800
> > > > > > >Email: michael.daw at man.ac.uk
> > > > > > >http://www.sve.man.ac.uk/General/Staff/daw
