[AG-TECH] Connection Interrupted?
Todd Zimmerman
todd.zimmerman at newmic.com
Wed Sep 3 15:18:37 CDT 2003
Hi All,
We've been getting a message box intermittantly on our main node that says:
"Your connection to the venue is interrupted and you will be removed from the
venue. Please, try to connect again."
After clicking "OK" I can enter the venue again, and all is well.
We're running AG 2.1.1 with Win2k on the Display machine and RH7.2 on the
capture machine; however, this issue also occured using AG 2.0. I'm not sure
how to reproduce it... it just seems to happen after a few hours of being in
a particular venue.
The offending section of the venueclient.log is attached below.
Sorry if this issue has already been discussed - I can't find a reference to
it at Bugzilla or the tech list.
Thanks for all your help!
Todd Zimmerman
Research Assistant - NewMIC
New Media Innovation Centre
Ph: 604.806.5100
begin venueclient.log
09/03/03 08:26:12 1476 AG.TextClient.TextConnection textclient.py:198 DEBUG
TextConnection: Got read handle=_b85de400_p_globus_io_handle_t ret=(-1, 2,
'an end-of-file was reached') n=0
09/03/03 08:26:12 1476 AG.TextClient.TextConnection textclient.py:201 DEBUG
TextConnection: asynch read gets n=0, EOF
09/03/03 08:26:12 1476 AG.VenueClient eventclient.py:186 DEBUG Got read
handle=_209ce200_p_globus_io_handle_t ret=(-1, 4, 'an end-of-file was
reached') n=0
09/03/03 08:26:12 1476 AG.VenueClient eventclient.py:194 DEBUG readCallback
gets failure in result: 4 an end-of-file was reached
09/03/03 08:26:16 1652 AG.VenueClient eventclient.py:287 ERROR Attempting to
send on a disconnected EventClient
09/03/03 08:26:16 1652 AG.VenueClient venueclient.py:147 ERROR
AccessGrid::VenueClient:Heartbeat: Heartbeat exception is caught, exit venue.
Traceback (most recent call last):
File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line 144,
in Heartbeat
self.privateId))
File "C:\Python22\Lib\site-packages\AccessGrid\EventClient.py", line 288,
in Send
raise EventClientWriteDataException
09/03/03 08:26:16 1460 AG.Types venueclient.py:398 DEBUG
bin::VenueClient::HandleServerConnectionFailure: call exit venue
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:664 INFO
VenueClient.ExitVenue
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:683 INFO Stopping
heartbeats
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:710 INFO Stopping
event client
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:712 DEBUG send client
exiting event
09/03/03 08:26:16 1460 AG.VenueClient eventclient.py:287 ERROR Attempting to
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:722 ERROR on client
exiting
File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line 714,
in ExitVenue
self.privateId))
in Send
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:724 INFO Stopping text
client
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:727 DEBUG sending
client disconnect event.
09/03/03 08:26:16 1460 AG.TextClient.TextConnection textclient.py:155 DEBUG
TextConnection.Write: EVENT --- Input
09/03/03 08:26:16 1460 AG.TextClient.TextConnection textclient.py:156 DEBUG
TextConnection.Write: Event:
Type: Disconnect Venue: 000000f5569d3d86008c00dd000b0037351 Data:
000000f764ad712b008c00dd000b003714b
09/03/03 08:26:16 1460 AG.TextClient.TextConnection textclient.py:145 DEBUG
TextClient.Stop
09/03/03 08:26:16 1460 AG.VenueClient venueclient.py:730 DEBUG remove
reference
09/03/03 08:26:17 1460 AG.VenueClient venueclient.py:738 ERROR
AccessGrid.VenueClient::ExitVenue exception
File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line 736,
in ExitVenue
self.venueProxy.Exit( self.privateId )
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py",
line 3650, in __call__
return self.__r_call(*args, **kw)
File
line 3670, in __r_call
self.__hd, self.__ma)
File
line 3570, in __call
config = self.config)
File "C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py",
line 185, in call
r.endheaders()
File "C:\Python22\lib\httplib.py", line 695, in endheaders
self._send_output()
File "C:\Python22\lib\httplib.py", line 581, in _send_output
self.send(msg)
File "C:\Python22\lib\httplib.py", line 548, in send
self.connect()
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1079, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663, in connect
raise ex
GSITCPSocketException: a system call failed (Invalid argument)
09/03/03 08:26:17 1460 AG.VenueClient venueclient.py:746 INFO Stopping node
services
