[AG-TECH] (newbie question) AGTk 2.1.2 certificate problem
Robert Olson
olson at mcs.anl.gov
Mon Oct 27 07:14:54 CST 2003
Hi --
(I'm guessing you might be hitting the unicode-in-pathnames problem).
Please bring up a command window and set the output of this command
set user
--bob
At 03:18 AM 10/27/2003, Dioselin Gonzalez wrote:
>Hi,
>I installed AGTk 2.1.2 on a single machine node with Windows XP. I
>followed the installation instructions but when I run Request
>Certificate, it won't do anything. I see the hourglass cursor for a
>while but then it does nothing. When I run the venue client, I get the
>following error and then it hangs:
>Application object creation failed
>ASCII encoding error: ordinal not in range (128)
>The venue client cannot continue
>Attached is the log file.
>Any help would be appreciated.
>Thank you,
>Dioselin.-
>Dioselin Gonzalez.-
>Graduate research assistant
>Envision Center for Data Perceptualization at Purdue
>http://www.itap.purdue.edu/viscenter/
>10/27/03 04:13:41 4068 AG.DataStore datastore.py:1615 DEBUG Creating thread 0
>10/27/03 04:13:41 4068 AG.DataStore datastore.py:1620 DEBUG Starting thread 0
>10/27/03 04:13:41 1968 AG.DataStore datastore.py:1628 DEBUG Worker 0 starting
>10/27/03 04:13:41 4068 AG.DataStore datastore.py:1622 DEBUG Waiting thread 0
>10/27/03 04:13:41 4068 AG.DataStore datastore.py:1625 DEBUG Done creating
>workers
>10/27/03 04:13:42 4068 AG.Types venueclient.py:135 ERROR
>bin.VenueClient::OnInit: WXGUIApplication creation failed
>Traceback (most recent call last):
> File "C:\Program Files\Access Grid Toolkit\bin\VenueClient.py", line
> 132, in __init__
> self.app = Toolkit.WXGUIApplication()
> File "C:\Python22\Lib\site-packages\AccessGrid\Toolkit.py", line 154,
> in __init__
> self.gui)
> File "C:\Python22\Lib\site-packages\AccessGrid\CertificateManager.py",
> line 226, in __init__
> if not os.path.isdir(self.userProfileDir) or \
>UnicodeError: ASCII encoding error: ordinal not in range(128)
>10/27/03 04:13:45 4068 AG.Types venueclient.py:929 INFO --------- END
>VenueClient
>10/27/03 04:13:45 4068 AG.Types venueclient.py:950 DEBUG Terminating services
