[AG-TECH] Windows, Rat, and multiple interfaces
Robert Olson
olson at mcs.anl.gov
Tue Oct 21 17:14:17 CDT 2003
Howdy folks --
We've been seeing growing problems with rat and Windows boxes with multiple
network interfaces. The symptom of the problem is that rat would not appear
when launched, and leave a ratui.exe process hanging about.
I've fixed rat to handle this situation properly; this new rat will be
available with 2.1.2 and as a separate (informal) zipfile release for those
who need it in that form.
In the short time I've been poking at this, we've come across a couple
failure modes that aren't really the fault of the rat code, but that cause
it to fail nonetheless. This note will discuss these problems and their
solutions.
I'll digress with a bit of network routing discussion first. If you have
multiple network interfaces, the OS has to decide how to route traffic
properly to these addresses. It uses a routing table for this. For example,
my laptop here at MCS is currently on both the wired and wireless network.
The routing table looks like this:
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 140.221.34.61 140.221.34.35 20
0.0.0.0 0.0.0.0 140.221.57.253 140.221.57.128 30
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
140.221.34.32 255.255.255.224 140.221.34.35 140.221.34.35 20
140.221.34.35 255.255.255.255 127.0.0.1 127.0.0.1 20
140.221.56.0 255.255.254.0 140.221.57.128 140.221.57.128 30
140.221.57.128 255.255.255.255 127.0.0.1 127.0.0.1 30
140.221.255.255 255.255.255.255 140.221.34.35 140.221.34.35 20
140.221.255.255 255.255.255.255 140.221.57.128 140.221.57.128 30
224.0.0.0 240.0.0.0 140.221.34.35 140.221.34.35 20
224.0.0.0 240.0.0.0 140.221.57.128 140.221.57.128 30
255.255.255.255 255.255.255.255 140.221.34.35 140.221.34.35 1
255.255.255.255 255.255.255.255 140.221.57.128 140.221.57.128 1
Default Gateway: 140.221.34.61
We'll concentrate on the multicast routes first, as those are what affect
rat. They are these:
This means to route traffic destined for 224.0.0.0 (the multicast address
range) via either 140.221.34.35 (my wired interface) or 140.221.57.128 (my
wireless interface). The choice between them is made based on the routes'
metric - 20 for the wired, and 30 for the wireless. Lower metric values
take precedence, so my laptop will be using wired net for outgoing
multicast traffic.
There is an additional consideration in the case of multicast where the
code that configures multicast sockets for the apps (rat in this case)
apparently, on Windows, needs to know the interface on which multicast
traffic is to be sent. The fixes made today use the Win32 IP Helper API to
determine the interface on which multicast traffic will flow, and configure
the sockets accordingly. This information comes from the routing table, as
we discussed above.
This leads to the problems we've seen. In one, a Cisco VPN software
installation failure apparently left a stray VPN interface configured and
enabled, which caused the multicast route to point out the VPN interface,
which of course didn't lead anywhere. Hence, rat failed.
In the other (on the same machine as it happens), the interface metric for
the wireless network was hardcoded. Apparently, some wireless drivers do
this, which causes the routing table to prefer the wireless network to the
wired network. It is often the case that a site that has wireless
networking will disable multicast on that network; if this is case, and if
the metrics are wrong, rat may come up but not see any multicast traffic.
The fix for this is to inspect the network interface settings. On XP, bring
up the network connections panel, right-click an interface, select
Properties, scroll down to "Internet Protocol (TCP/IP)", click Properties,
click Advanced, and ensure that "Automatic Metric" is checked.
When this has been done on all interfaces, Windows should assign the lowest
metric to the fastest network connection. See the following article for
more information on this.
http://www.winnetmag.com/MobileWireless/Article/ArticleID/24163/MobileWireless_24163.html
Microsoft's knowledge base also has this:
http://support.microsoft.com/default.aspx?scid=kb;en-us;299540
Ah, this is an XP-only thing. If folks have problems with this on Win2k,
please drop me a note and we can figure something out. It appears that
metrics can be manually set there for the appropriate behavior. (Yes,
that's the case. I just verified that with my Win2k box that has a couple
VMWare interfaces configured that in the past had always interfered with rat).
http://support.microsoft.com/default.aspx?scid=kb;EN-US;258487
--bob
