[AG-TECH] Re: AG Installation
Chun-Yu CHAN
cychan at hpc.unm.edu
Mon Nov 24 13:12:50 CST 2003
Hello,
the certificate approval thing some time take days. Just wait. And play
with the beacon client that I emailed you earlier.
Sincerely,
cychan
On Mon, 24 Nov 2003, Lee Derks wrote:
> Hi Jennifer,
> The "request certificate" function does not respond at all and does
> not give any error message. I wasn't really sure if I needed to run Node
> Setup but I was just testing the application to see if it would respond.
> We are supposed to get Multicast enabled this afternoon and will try again
> tomorrow.
> Thanks!
> Lee
> > Hmm, that's strange behavior; I don't believe the lack of multicast
> > would have any effect on the "request certificate" function. Does it
> > just not respond at all, or does it give you any kind of error message?
> > I'm also not sure why you'd need to run the Node Setup wizard on a
> > personal node, but perhaps I'm just missing something here.
> > I'm cc-ing ag-tech, since I haven't seen anything like this before but
> > perhaps somebody else has.
> > Cheers,
> > Jennifer
> > Lee Derks wrote:
> > > Hi Jennifer,
> > > I'm sorry to bother you with AG software installation questions, but we
> > > are trying to set up an AG PIG at the TVN main office. As of today,
> > > multicast is not enabled on our router but it will be by Monday. I went to
> > > the Access Grid software page and downloaded Python 2.2, wxPython 2.4, and
> > > the AG Toolkit 2.1.2. I also installed the software in that order. I do not
> > > have a Globus security certificate. When I try requesting a certificate
> > > through the program "Request Certificate," the application does not do
> > > anything. Do I need to launch other applications before I can request a
> > > certificate? Or, is it because Multicast is not enabled? I also tried
> > > launching the program "Node Setup Wizard" and that did not work either.
> > > Thank you for your help
> > > Lee Derks
> Lee Derks
> UNM Undergrad
> BBA/MIS
> derksL at unm.edu
:-)!!! Sam Kinnison
# The Center for High Performance Computing at UNM (HPC at UNM)
# Chun-Yu CHAN # Systems Analyst II
# Phone: (505) 277-8339 Fax: (505) 277-8235 Mobile: (505) 450-5619
