[AG-TECH] Updated image viewer
Dave Semeraro
semeraro at ncsa.uiuc.edu
Fri Nov 14 12:46:33 CST 2003
Hi Techers,
I have attached a new version of the image viewer program. The improved
version is compatible
with AG2.1 and the new way to register applications with the venue client.
In addition the
application stores the image in the venue data area instead of the
application object. Thanks
to Tom Uram for making these changes for me. I added the drag and drop
capability and fixed
a bug that would cause a previous image to persist when a smaller image was
loaded. Both of
these things are simple fixes. Still to do is add the markup capability and
scrolled window
capability. Hey, I still have a couple of more days before SC :).
The new code has been verified under windows and Linux. To register the
shared application
save the attachments ( AGBasicImage.py and AGBasicImage.app) somewhere and
run the
package manager tool from the same directory like this:
c:\directorywithappfile> agpm.py -f AGBasicImage.app
That should do the trick. After that just fire up the venueclient, add the
BasicImage application,
drag an image file to it and enjoy.. I hope.
Anyway that is about it. I hope you find this version useful.
Dave
Dave Semeraro Ph.D.
Visualization and Virtual Environments Group
NCSA University of Illinois
605 E. Springfield Ave.
Champaign, IL 61820
Semeraro at ncsa.uiuc.edu
(217) 244-1852
This is the Access Grid Enabled version of the Basic Image viewer. It does the same
thing as the Basic Image ( load an image into a window ) but will share the image over
the Access Grid. Again there is no way to pan or scroll the window. This is just an
attempt to get the BasicImage viewer to work over the AG. The scheme is that the script is executed
and given an application URL... like this AGBasicImage appurl. There is no error handling in
this version.
Dave Semeraro
NCSA-UIUC
Modifications:
- Change state from image data stored in the appobject to the name of a
venue-resident image file
- If a local file is opened, it is transferred to the venue
# generic and gui related imports
import os
import sys
from wxPython.wx import *
import base64
import cPickle
import string
# AG related imports
import logging
from AccessGrid.hosting.pyGlobus import Client
from AccessGrid import Events
from AccessGrid import EventClient
from AccessGrid import Platform
from AccessGrid.DataStoreClient import GetVenueDataStore
ID_OPEN = wxNewId()
ID_OPEN_VENUE = wxNewId()
ID_EXIT = wxNewId()
wildcard = "JPEG Files (*.JPG)|*.jpg|"\
"Gif Files (*.GIF)|*.gif|"\
"All Files (*.*)|*.*"
class BIFileDropTarget(wxFileDropTarget):
def __init__(self,window):
wxFileDropTarget.__init__(self)
self.window = window
def OnDropFiles(self,x,y,filenames):
for file in filenames:
self.window.wind.LoadImageFromFilename(file)
# load up the dropped file into venue
self.window.AG.UploadFile(file)
self.window.AG.PutData(self.window.imagedataname,os.path.split(file)[1])
# fire event telling all there is new data
self.window.AG.SendEvent("NewImage",os.path.split(file)[1])
# this is an image holder object.. guess what it does.
class ImageHolder:
def __init__(self,image,name):
self.imagename = name
self.width = str(image.GetWidth())
self.height = str(image.GetHeight())
self.data = base64.encodestring(image.GetData())
# A helper class to hide all the AG ugly
class AGSharedObject:
def __init__(self,url,venueUrl):
self.logname = "AGBasicImagelog"
self.appUrl = None
self.appName = "Basic Image"
self.appDescription = "Access Grid Shared Image"
self.appMimetype = "application/x-ag-basic-image"
self.init_logging(self.logname)
self.log.debug("AGSharedObject: initialize with url = %s ", url)
self.appUrl = url
self.log.debug("AGSharedObject: Getting application proxy")
self.appProxy = Client.Handle(self.appUrl).GetProxy()
self.log.debug("AGSharedObject: join application")
(self.puid,self.prid) = self.appProxy.Join()
self.log.debug("AGSharedObject: get data channel")
(self.chanid,self.esl) = self.appProxy.GetDataChannel(self.prid)
self.eventClient = EventClient.EventClient(self.prid,self.esl,self.chanid)
self.eventClient.Start()
self.eventClient.Send(Events.ConnectEvent(self.chanid,self.prid))
self.log.debug("AGSharedObject: connected and event channel started")
self.dataStoreClient = GetVenueDataStore(venueUrl)
def init_logging(self,logname):
logFormat = "%(name)-17s %(asctime)s %(levelname)-5s %(message)s"
self.log = logging.getLogger(logname)
self.log.setLevel(logging.DEBUG)
self.log.addHandler(logging.StreamHandler())
def GetData(self,dataname):
self.log.debug("looking for data: %s", dataname)
tim = self.appProxy.GetData(self.prid,dataname)
if len(tim) > 0:
return tim
else:
return None
def PutData(self,dataname,data):
self.log.debug("loading data named: %s into server",dataname)
self.appProxy.SetData(self.prid,dataname,data)
def RegisterEvent(self,eventname,callback):
self.log.debug("Registering event %s :",eventname)
self.eventClient.RegisterCallback(eventname,callback)
def SendEvent(self,eventname,eventdata):
self.eventClient.Send(Events.Event(eventname,self.chanid,(self.puid,eventdata)))
def UploadFile(self,localFile):
# Upload the file
self.dataStoreClient.Upload(localFile)
# Construct the venue data url
file = os.path.split(localFile)[-1]
venueDataUrl = os.path.join(self.dataStoreClient.uploadURL, file)
return venueDataUrl
def DownloadFile(self,venueDataUrl):
# Construct the local filename
file = os.path.split(venueDataUrl)[-1]
path = os.path.join(Platform.GetTempDir(),file)
# Update the local store of venue data
self.dataStoreClient.LoadData()
# Download the file
self.dataStoreClient.Download(venueDataUrl,file)
return file
class ImageWindow(wxWindow):
def __init__(self,parent,ID):
wxWindow.__init__(self,parent,ID,style=wxNO_FULL_REPAINT_ON_RESIZE)
self.imagefile = None
self.image = None
self.SetBackgroundColour("WHITE")
self.InitBuffer()
EVT_IDLE(self,self.OnIdle)
EVT_SIZE(self,self.OnSize)
EVT_PAINT(self,self.OnPaint)
def InitBuffer(self):
size = self.GetClientSize()
if self.image == None:
self.buffer = wxEmptyBitmap(size.width,size.height)
dc = wxBufferedDC(None,self.buffer)
dc.SetBackground(wxBrush(self.GetBackgroundColour()))
dc.Clear()
else:
self.Clear()
self.buffer = self.image.ConvertToBitmap()
self.reInitBuffer = false
def LoadImageFromFilename(self,imagefilename):
self.imagefile = imagefilename
self.image = wxImage(self.imagefile)
self.reInitBuffer = true
self.Refresh(true)
def LoadImage(self,animage):
imgdat = base64.decodestring(animage.data)
self.image = wxEmptyImage(string.atoi(animage.width),string.atoi(animage.height))
self.image.SetData(imgdat)
def OnIdle(self,event):
if self.reInitBuffer:
self.InitBuffer()
self.Refresh(FALSE)
def OnSize(self,event):
def OnPaint(self,event):
dc = wxBufferedPaintDC(self,self.buffer)
class ImageFrame(wxFrame):
wxFrame.__init__(self,parent,ID,"AGImage: no image loaded",size=(800,600),
style=wxDEFAULT_FRAME_STYLE | wxNO_FULL_REPAINT_ON_RESIZE)
menu = wxMenu()
menu.Append(ID_OPEN,"&Open...","Open an image file")
menu.Append(ID_OPEN_VENUE,"&Open from venue...","Open a venue image file")
menu.AppendSeparator()
menu.Append(ID_EXIT,"&Exit","Terminate with extreme prejudice")
menubar = wxMenuBar()
menubar.Append(menu,"&File")
self.SetMenuBar(menubar)
EVT_MENU(self,ID_OPEN, self.On_Open)
EVT_MENU(self,ID_OPEN_VENUE, self.On_OpenVenue)
EVT_MENU(self,ID_EXIT, self.On_Exit)
# start the ag stuff and see if there is an image already there
self.imagedataname = "ImageFile"
self.wind = ImageWindow(self,-1)
dt=BIFileDropTarget(self)
self.SetDropTarget(dt)
self.AG = AGSharedObject(sys.argv[1], sys.argv[2])
self.AG.RegisterEvent("NewImage",self.HandleNewImage)
animage = self.AG.GetData(self.imagedataname)
if animage == None:
print "No image found in server"
else:
print "Loading image: ", animage
localImageFile = self.AG.DownloadFile(animage)
self.LoadImageFromFilename(localImageFile)
def On_Open(self,event):
dlg = wxFileDialog(self,"Select An Image", os.getcwd(), "",wildcard,wxOPEN)
if dlg.ShowModal() == wxID_OK:
# Load the image locally
localImageFile = dlg.GetPath()
# Push the data to the venue server
# - copy the image to the venue server
venueImageFile = self.AG.UploadFile(localImageFile)
file = os.path.split(localImageFile)[-1]
# - store the image url in the app object
self.AG.PutData(self.imagedataname, file)
# Now fire the event that tells everyone else the image is changed
self.AG.SendEvent("NewImage",file)
def On_OpenVenue(self,event):
self.AG.dataStoreClient.LoadData()
# Let user select a venue file
dlg = wxSingleChoiceDialog( self, "Select an image file to load", "Load Venue Image Dialog",
self.AG.dataStoreClient.dataIndex.keys() )
venueImageFile = dlg.GetStringSelection()
# Download the file locally
localImageFile = self.AG.DownloadFile(venueImageFile)
# Store the image url in the app object
self.AG.PutData(self.imagedataname, venueImageFile)
# Load it
def HandleNewImage(self,eventdata):
# received notification that there is a new image on the server
(senderId,venueImageFile) = eventdata.data
if senderId != self.AG.puid:
try:
# Load the image
except:
print "EXCEPTION : ", sys.exc_type, sys.exc_value
import traceback
traceback.print_stack()
def LoadImageFromFilename(self,filename):
# Load the image
self.wind.LoadImageFromFilename(filename)
# Set the window title
title = os.path.split(filename)[-1]
self.SetTitle(title)
def On_Exit(self,event):
self.Close(true)
class MyApp(wxApp):
def OnInit(self):
wxInitAllImageHandlers()
frame = ImageFrame(None,-1)
frame.Show(true)
self.SetTopWindow(frame)
return true
app = MyApp(0)
app.MainLoop()
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031114/e9f721ad/attachment.obj>
