[AG-TECH] installation problems for ag2.1.2
Thomas D. Uram
turam at mcs.anl.gov
Thu Nov 6 09:53:42 CST 2003
Deb:
I need more information to understand the problem. If you send logfiles
from the display machine, I'm sure I can fix the problem for you right
away. I need the following files from C:\Documents and
Settings\<YOU>\Application Data\AccessGrid:
VenueClient.log
agns.log
agsm.log
Tom
Deb Agarwal wrote:
> I was running ag2.1.1 and needed to upgrade to 2.1.2 for a demo
> today but things appear to have gone wrong somewhere. This is
> on my node with one winXP box and two linux boxes. On the linux
> boxes I did not uninstall anything and just ran the 2.1.2 install.sh.
> Everything seemed to work fine there and the service managers run
> on those machines. On the winxp box I uninstalled the AG2.1.1 (
> but left wxpython or Activepython). Then I installed AG2.1.2 and
> everything seemed to go fine. I then imported my certificate and
> proceeded to run the venue client. The venue client ran fine and
> connected to the venue server but it did not run vic. So, then
> I tried the manage node option on the menus but it said that the
> service manager was not running. So, I tried running a service
> manager in its own window. I still can't get the venue client to
> connect to the service manager. Then I tried running the configure
> node python script in the Access Grid Toolkit and configuring things
> that way. I answer the questions, and printouts start appearing in the
> service manager window and the vid and aud machine service managers
> show various text printouts but the display machine service manager
> eventually gets an exception trying to start something on the
> display machine and gives up.
> Any idea what I did wrong? I will not be near the machine today
> but I need to generate a set of instructions for one of my
> colleagues to follow and get the display machine running properly.
> Any suggestions on how I can get things running with the simplest
> set of instructions (I realize this may be uninstall everything)?
> Thanks for any help.
> Deb Agarwal
