[AG-TECH] help with vic and rat startup - default settings
Allan Spale
aspale at evl.uic.edu
Tue May 20 09:39:48 CDT 2003
Hello,
You can use a feature in vic called Autoplace. Press the Autoplace button
and then drag an area of the display where you want video windows to
appear. You can adjust the size of the video windows by selecting the
window size at the bottom of the dialog. Press the "Write vic.prefs"
button so your selection persists between grid sessions. Then press the
Apply button to see how things appear.
Allan
EVL at UIC
Research Assistant
On 20 May 2003, Grzesiek Sedek wrote:
> I've solved this problem, vic's tcl script had wrong permissions.
> But now I wonder if there is a possibility to open video streams by
> default on startup?
> Thank you
> On Tue, 2003-05-20 at 13:56, Robert Olson wrote:
> > what do you mean video does not go out? Do you see your video in vic window
> > at all? What capture device does vic show it is using?
> > At 02:44 AM 5/20/2003 +0100, Grzesiek Sedek wrote:
> > >Yep, it's fine, but after a while of testing with vic ant tcl script for
> > >it I still don't seem to send a video to the network, all the settings
> > >seem to be fine ( transmit button pressed, frame rates and the rest )
> > >but video does not go out.
