[AG-TECH] After starting VenueClient.py ??
nikhil
nikhil at east.isi.edu
Thu May 15 10:56:15 CDT 2003
I am in the venue "https://vv2.mcs.anl.gov:9000/Venues/default". I see myself
and other participants listed under Participants. Now i select MyNode->Manage
which pops up another window. Then i select File->Attach_to_Node and enter
the hostname of my machine. Then when i want to add service from a pop down
menu, it fails ??
Nikhil
PS: By the way I am also able to run the same s/w on my previous RH 7.0
machine.
On Thursday 15 May 2003 06:58 pm, Jennifer Teig von Hoffman wrote:
> Hi Nikhil,
> You might be looking at an outdated set of instructions, assuming you've
> installed Release Candidate 1; please try:
> http://scv.bu.edu/~jtvh/AGTk2/rc1.txt
> When the venues client opens, you should click "Go".
> - Jennifer
> nikhil wrote:
> >Hi,
> >After installing the complete AG s/w on my RH 7.3 machine, I started
> >VenueClient.py. It opens up a window and the URL shown is :
> >https://vv2.mcs.anl.gov:9000/Venues/default.
> >But on top it displays "You are not in a Venue". Then i select
> > MyNode->Manage (as per instructions given on a web page link) which pops
> > up another window. Now what ? How do i connect to a venue and start
> > communicating ? I browsed thru the online documentation but found no
> > instructions to go step-by-step. Thanks for your help.
> >Nikhil
Computer Networks Division
USC Information Sciences Institute
Arlington, VA 22203
