[AG-TECH] AG 2.0/Globus cert question
Frank Sweetser
fs at wpi.edu
Thu May 8 19:42:20 CDT 2003
On Thu, May 08, 2003 at 04:09:49PM -0600, Darin Oman wrote:
> I will be running AG 2.0 in one form or another on a few different machines
> (main node, my laptop, etc.). Is it OK to use the same certificate for all
> machines, or should I request a separate cert for each? Is there a problem if
> there are 2 nodes running at the same time using the same cert?
I've run AG2 in the same venue with the same cert fron different machines at
the same time without any problems.
Frank Sweetser fs at wpi.edu
WPI Network Engineer
