[AG-TECH] Osprey 210 Simulstream?
Michael Gates
mgates at sdsc.edu
Tue Mar 25 10:46:00 CST 2003
I run the simpler Osprey 100 cards and got the same message. You have to
configure each VIC capture (not display) to point to each different osprey
card and you won't get the message anymore. If you only have a single
osprey card and are getting the message, then make sure that there aren't
ANY other applications running that would talk to the card (config/control
apps, old instances of VIC that don't show in the taskbar but do show in
task manager, etc).
As I understand it, the display VIC gets all of the video streams from the
network (including the local one), so it should not be accessing the video
capture card.
hope this helps,
-Mike
Michael Gates
Access Grid and Videoteleconference
Support and User Services
mgates at sdsc.edu
858.534.8369
mgates at pager.sdsc.edu
Room A-5
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Gurcharan S. Khanna
Sent: Monday, March 24, 2003 21:09
To: Randy Groves; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Osprey 210 Simulstream?
hi,
i just installed these cards in a PIG, too, but haven't noticed a problem.
however, i just assumed the muted thumbnails were responsible for the
grayed-out images on the capture windows. i'll go back and double-check
this,
but i didn't get any messages about "simulstream" either.
-gurcharan
--- Randy Groves wrote:
Just installed a new node machine, with a Osprey 210, and the PIG. This
card
came with newer drivers than I have on other machines of mine, and it looks
like they've split out the capability for multiple applications to grab the
stream from a single card. As a result, I get a message that I need to
purchase the 'Simulstream' capability for this card (for $600!!!) in order
for
the picture to show up in both the Display and Capture windows. Is my
analysis
of the situation correct? In the older drivers, this capability seems to
have
been included.
Anybody else run into this?
-randy
--- end of quote ---
Gurcharan S. Khanna
Associate Director
Research Computing
Dartmouth College
tele: 603-646-1644
http://research.dartmouth.edu
http://www.dartmouth.edu/~gkhanna
