[AG-TECH] multi machine AG2.0
George Estes gestes at ncsa.uiuc.edu
Tue Jun 24 14:36:22 CDT 2003
Frank, you nailed it.  Replaced local_services directory and moved .zip
file to /tmp/local_services and it works again.  Not sure why AG2.0 is
using /tmp?
At 01:27 PM 6/24/2003 -0400, you wrote:
>On Tue, Jun 24, 2003 at 11:32:58AM -0500, George Estes wrote:
> >     I'm running AG2.0 on three machines.  When I attempt to add a service
> > to the audio or video machine I get this error:
> > Exception: Error adding service: Exception: AGServiceManager.AddService
> > failed: [Errno 2} No such file or directory:
> > '/tmp/local_service/VideoProducerService.zip'
> >     Anyone else have this problem?
>Does the directory /tmp/local_service/ and the corresponding zip files exist?
>If not, then did you install the VideoProducer rpm?  And if so, perhaps they
>got cleaned out by a /tmp scrubber.
>BTW, is there any good reason why the AG rpms keep important files in /tmp?
>Frank Sweetser fs at wpi.edu
>WPI Network Engineer
More information about the ag-tech mailing list
