[AG-TECH] AG 2.0 issues
Markus Buchhorn
Markus.Buchhorn at anu.edu.au
Tue Jun 3 18:57:17 CDT 2003
At 10:53 3/06/2003 -0500, Alex Colomb wrote:
> * When using the Venue Client with a quickcam 4000, there is no way to choose the built-in mic on the camera in rat.
Under Linux I found rat (or linux) only picks up one audio device. Under Windows it picks up all of them (and then you need to convince rat to use the right one - it's not the 'Windows default audio device').
> * When moving single stream video windows around the screen in the Venue Client, the window shrinks in the vertical as it is moved (the bottom of the window frame moves up gradually all the way to the menu bar)
> * The 2.0 Venue Client app stops responding after extended use
>Granted, any of these issues could be setup specific. Anyone else encounter anything like this?
Haven't seen these, but can add
- video config doesn't allow for PAL inputs (minor setup hack needed)
- audio config doesn't allow rat to come up 'talk enabled' (or 'mike-on'? Minor setup hack I suspect)
- video config, slider for bandwidth setting, you can drag it way off the edge of the window :-)
This is under 2.0 on W2k.
[Rhys - do you want to add these to the AGBugzilla?]
Is the AG2 CVS writable to non ANL people?
Cheers,
Markus
Markus Buchhorn, ANU Internet Futures Project, | Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au, mail: Bldg #108 - CS&IT |Fax: +61 2 61259805
Australian National University, Canberra 0200, Aust.|Mob: 0417 281429
