[AG-TECH] Network Flow diagrams
Andrew Shewmaker`
shewa at inel.gov
Mon Jan 20 09:23:21 CST 2003
On Mon, 20 Jan 2003 12:30:47 +0000
Philip J McCormick <mccormick at uk.ibm.com> wrote:
> I've had a look in the AG docs for a diagram that shows the ports and
> network protocols used by the applications running on the AG machines
> (Display, Audio and Video), but I can't find one. Does anyone know the
> location of such a diagram or have one they can send me?
> I've knocked up a quick example of the kind of thing I need. I'll use this
> one if there aren't any others out there......does it look correct?
> anything missing?
> (See attached file: net_flow.jpg)
> Thanks
> Phil McCormick
> MCCORMIC at UK.IBM.COM
You will probably want to add:
Display: access grid beacon server (HTTP TCP 9999), NTP (TCP/UDP 123),
VNC (TCP 5800,5900,others?)
Video: NTP (TCP/UDP 123), SSH (TCP/UDP 22)
Audio: NTP (TCP/UDP 123), SSH (TCP/UDP 22)
But I'm just a beginner and there are probably others I've missed, or
perhaps people are using different VNC ports.
Andrew
Andrew Shewmaker
Associate Engineer
Phone: 208.526.1415
Fax: 208.526.4017
Idaho National Engineering and Environmental Laboratory
2525 Fremont Ave.
Idaho Falls, ID 83415-3605
