[AG-TECH] Issue with RedHat 7.2, rat, and full duplex
Colin Perkins csp at isi.edu
Tue Feb 25 15:04:57 CST 2003
--> Robert Olson writes:
>ah, that'd be the probelm. The delta is sort of a funky device. Notice that
>it shows up as having separate input and output devices, not unified full
>duplex in/out devices.
>I think that for rat to work properly with this device it will require
>modifications to the rat audio driver to use the different devices for
>input and output.
Correct. I wrote some code to try to cope with this (e.g. look at the
oss_test_device_pair() routine in auddev_oss.c), but it never quite
worked right, and I didn't have the hardware to test on...
Colin
More information about the ag-tech mailing list
