[AG-TECH] RE: AGTk 2.0 alpha 3 Available
Ivan R. Judson
judson at mcs.anl.gov
Tue Feb 25 11:01:58 CST 2003
Hey Mike,
There is a new dependancy that I'm putting on the prerequisite pages now.
It was a bit of a surprise that it got slipped in last week (were were
slating it for this week :-).
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Daw
> Sent: Tuesday, February 25, 2003 5:37 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] RE: AGTk 2.0 alpha 3 Available
> I'm getting a problem installing this. My problem is thus:
> [root at george RPMs]# rpm -Uvh AccessGrid-2.0alpha-3.i386.rpm
> error: failed dependencies:
> logging is needed by AccessGrid-2.0alpha-3
> Before you think I'm being (completely) stupid, I have
> reinstalled (updated,
> actually) all the new rpms (i.e. gpt 1.0.2, data management
> 2.0.2, pyGlobus 2).
> One difference in what I'm doing that other people may not is
> that I still have to run 'rpm -Uvh --force --nodeps
> pyGlobus-cvs-2.i386.rpm' (bug #14) to install pyGlobus.
> Any help before I crawl my way into Bugzilla...? (By the way,
> Ivan, despite your comment, you *still* haven't fixed bug #25
> [not that I'm checking up on you or anything]!)
> --Mike
> > From: owner-ag-announce at mcs.anl.gov
> > [mailto:owner-ag-announce at mcs.anl.gov]On Behalf Of Ivan R. Judson
> > Sent: 22 February 2003 01:15
> > To: ag-announce at mcs.anl.gov; ag-tech at mcs.anl.gov
> > Subject: AGTk 2.0 alpha 3 Available
> > The Access Grid Toolkit v.2.0-alpha-3 is available for download.
> > Components that have been updated since 02/14/2003:
> > globus (windows only)
> > The Access Grid Toolkit (windows and linux)
> > New Requirements since 02/14/2003:
> > The python logging module (windows and linux)
> > Known Issues:
> > Node Management
> > - No services are found. (linux only) (Bug 49)
> > Workaround: Start AGNodeService.py from /usr/share/AccessGrid
> > - The services list may not update after adding a service.(Bug 53)
> > Workaround: Click on View/Update and then on then rechoosing the
> > host refreshes this list
> > - Loading a config fails with "No such file or directory". (linux
> > only) (Bug
> > 54)
> > - VideoProducerService fails to find a configured device. (linux
> > only) (Bug
> > 58)
> > Workaround: Run SetupVideo.py from /usr/share/AccessGrid
> and start
> > AGServiceManager.py from /usr/share/AccessGrid.
> > - Installing with one network connection and then later
> trying to run
> > with a different network active fails. (Bug 79) (windows only)
> > Media Tools
> > - rat does not start when entering a venue (Bug 65) (linux only)
> > - QuickCam 4000 produces garbage video (Bug 66) (linux only)
> > Venue Server
> > - Enter venue fails. (Bug 21)
> > - Address already in use error. (Bug 22)
> > - Starting 2 venues on 2 different ports fails. (Bug 28)
> > - No static addressing. (Bug 44)
> > - IP address mask set wrong. (Bug 64)
> > - Can't have more than 20 venues (Bug 72)
> > - Venue server cause client and node management to hand (Bug 77)
> > - Venue server hangs if telnetted into and fed garbage (Bug 81)
> > Venue Client
> > - Tries to connect to bogus test.com on startup (Bug 62)
> > - "Local echo" cause exception in PyText (Bug 68)
> > - VenueClient process doesn't end after UI closes (Bug 70)
> > - Upload file dialog unreadable (Bug 71)
> > - Profile info window not in foreground (Bug 75)
> > - vic and rat don't start on entry (Bug 76)
> > Workaround: leave and re-enter venue
> > - Crashes when closing if never connected to venue (Bug 80)
> > Fixes Since 02/14/2003:
> > - Bug 19
> > - Bug 35
> > - Bug 39
> > - Bug 41
> > - Bug 42
> > - Bug 43
> > - Bug 46
> > - Bug 48
> > - Bug 51
> > - Bug 52
> > - Bug 57
> > - Bug 59
> > - Bug 61
> > - Bug 63
> > - Bug 82
> > Reporting Bugs:
> > To report any bugs or feature requests, please use our
> bugzilla server
> > at http://bugzilla.mcs.anl.gov/accessgrid
> > Getting the Software:
> > To download the software go to
> > http://www.mcs.anl.gov/fl/research/accessgrid/software and
> follow the
> > instructions there.
> > The AGTk Team
