[AG-TECH] Running Venues Server Alpha2
Ti Leggett
leggett at mcs.anl.gov
Mon Feb 17 10:51:14 CST 2003
What I think is happening is globus assumes if you're running as root
you're starting a proxy against the _host_ cert. Note the cert_dir as
being /etc/grid-security. I would run these things as a normal user as
Bob suggests.
On Mon, 2003-02-17 at 10:10, Robert Olson wrote:
> At 04:02 PM 2/17/2003 +0000, Michael Daw wrote:
> >root at george bin]# grid-proxy-init -debug
> >Files being used:
> > cert_file: none
> > cert_dir : /etc/grid-security/certificates
> > proxy : /tmp/x509up_u0
> > user_cert: none
> > user_key : none
> Note the "none" for user_cert and user_key; I think globus may really want
> to run as a normal user rather than root. did you set up a .globus
> directory with your globus usercert.pem and userkey.pem files?
> --bob
Ti Leggett <leggett at mcs.anl.gov>
