[AG-TECH] AG 2.1.2 install can't contact venue server
Phil Stanford
pns at soc.soton.ac.uk
Tue Dec 16 09:26:00 CST 2003
I've done an installation on a Windows 2000 machine of AG2.1.2 as a PIG.
I'm having problems with the Venue Client connecting to the default Venue
Server.
I'm getting 'No reachable venue at given venue URL' and 'Authorisation
failure' as per the trace below.
I'm using a UK e-Science certificate, but I think that the proxy cert is
being set up OK
I don't *think* it's a firewalling issue as an Ethereal trace (capture
file available if it'll help) does show the venue client contacting the
server on port 9000 and a brief conversation ensues, during which I can
see the plain-text bits of my cert being sent to the server.
I'm sure it's a very silly mistake on my part but I'd welcome clues ...
Thanks
Phil
12/15/03 16:29:05 DEBUG Creating thread 0
12/15/03 16:29:05 DEBUG Starting thread 0
12/15/03 16:29:05 DEBUG Worker 0 starting
12/15/03 16:29:05 DEBUG Waiting thread 0
12/15/03 16:29:05 DEBUG Done creating workers
12/15/03 16:29:05 DEBUG Reading persisted data from: C:\Documents and
Settings\p
ns\Application Data\AccessGrid\personalDataStore\DataStore.dat
C:\PROGRA~1\ACCESS~2\bin\agpm.py:57: RuntimeWarning: tmpnam is a potential
secur
ity risk to your program
workingDir = os.path.join(GetTempDir(), os.path.basename(os.tmpnam()))
secur
12/15/03 16:29:15 DEBUG userConfigDir: C:\Documents and
Settings\pns\Application
Data\AccessGrid
12/15/03 16:29:15 DEBUG Opened repository C:\Documents and
ion Data\AccessGrid\certRepo
12/15/03 16:29:15 DEBUG Unlink C:\Documents and Settings\pns\Application
Data\Ac
cessGrid\trustedCACerts\42864e48.signing_policy
Data\Ac
cessGrid\trustedCACerts\45cc9e80.signing_policy
Data\Ac
cessGrid\trustedCACerts\01621954.0
Data\Ac
cessGrid\trustedCACerts\01621954.signing_policy
Data\Ac
cessGrid\trustedCACerts\42864e48.0
Data\Ac
cessGrid\trustedCACerts\45cc9e80.0
12/15/03 16:29:15 DEBUG Using default identity
/C=UK/O=eScience/OU=Southampton/L
=SOC/CN=phil stanford
12/15/03 16:29:15 DEBUG Initializing environment with proxy cert for
/C=UK/O=eSc
ience/OU=Southampton/L=SOC/CN=phil stanford
12/15/03 16:29:15 DEBUG Configuring for user proxy issued from
/C=UK/O=eScience/
12/15/03 16:29:15 DEBUG Proxy C:\DOCUME~1\pns\LOCALS~1\Temp\x509_up_pns
will exp
ire 12/15/03 18:54:40
12/15/03 16:29:15 DEBUG bin.VenueClient::OnInit: ispersonal=1
AGServiceManager URL: https://152.78.109.40:12000/ServiceManager
Running Service; options: C:\Python22\python.exe [u'C:\\Documents and
Settings\\
pns\\Application Data\\AccessGrid\\local_services\\AudioService.py',
50848]
Trying client handle
Wait another sec for service to boot
- elapsedTries = 0
- elapsedTries = 1
- elapsedTries = 2
Starting server at https://152.78.109.40:50848/Service
* * Service handle is valid !
Settings\\
pns\\Application
Data\\AccessGrid\\local_services\\VideoConsumerService.py', 501
88]
- elapsedTries = 0
- elapsedTries = 1
- elapsedTries = 2
Starting server at https://152.78.109.40:50188/Service
12/15/03 16:29:47 DEBUG bin.VenueClient::OnInit: setting node service
URI to https://localhost:11000/NodeService from
PersonalNode
12/15/03 16:29:47 DEBUG bin.VenueClient: SetProfile
AGNodeService URL: https://152.78.109.40:11000/NodeService
12/15/03 16:30:16 DEBUG HaveValidProxy: found proxy ident
uthampton/L=SOC/CN=phil stanford/CN=proxy
12/15/03 16:30:16 DEBUG Set history url: None
12/15/03 16:30:27 ERROR AccessGrid.VenueClient::EnterVenue failed; time is
okay
(offset=0
Traceback (most recent call last):
File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line
458, in E
nterVenue
Client.Handle( URL ).IsValid()
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py", li
ne 83, in IsValid
ret = proxy._IsValid()
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py",
line 3660, in __call__
return self.__r_call(*args, **kw)
File
line 3680, in __r_call
self.__hd, self.__ma)
File
line 3580, in __call
config = self.config)
File
ne 188, in call
r.endheaders()
File "C:\Python22\lib\httplib.py", line 695, in endheaders
self._send_output()
File "C:\Python22\lib\httplib.py", line 581, in _send_output
self.send(msg)
File "C:\Python22\lib\httplib.py", line 548, in send
self.connect()
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1084, in
connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663, in
connect
raise ex
GSITCPSocketException: an authentication operation failed
466, in E
nterVenue
raise EnterVenueException("No reachable venue at given venue URL")
EnterVenueException: No reachable venue at given venue URL
12/15/03 16:30:27 DEBUG bin.VenueClient::EnterVenue: Enter venue with url:
https
://vv2.mcs.anl.gov:9000/Venues/default
12/15/03 16:30:30 DEBUG Authorization failure connecting to server.
