[AG-TECH] VenueServer Problem , please help urgently
Himani Gandhi
csa02037 at cse.iitd.ernet.in
Mon Dec 1 19:00:38 CST 2003
Hi all ,
One more piece of info , I should give you , Jus in case that helps to
debug
my problem .
I had already gt3.0 installed on the system before I set up the AG2.1.2.
Now could that be " ANY " possible configuration / library mismatch for
the module from which the exception is being raised ??
People who are wokring on that chunk of the code , please help .
Thanks again !
Regards
Himani
On Tue, 2 Dec 2003, Himani Gandhi wrote:
> Date: Tue, 2 Dec 2003 06:26:16 +0530 (IST)
> From: Himani Gandhi <csa02037 at cse.iitd.ernet.in>
> To: Ivan R. Judson <judson at mcs.anl.gov>
> Cc: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] VenueServer Problem , please help urgently
> HI Ivan ,
> Thanks for the feedback .
> Though I have been able to figure out myself , by browsing through the
> code .
> Meanwhile , for my Linux CA and Windows2k personal node setup . I have
> been able to " hack " the certificates by creating them offline and
> putting them at the required directories for the trusted CA certs and the
> user ca cert .
> NOW MY PROBLEM IS :
> I am running the server on the as per the instructions at :
> http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
> I am able to run : VenueServer.py
> but when I run : VenueManagement.py
> and type the URL of the VenueServer and try to connect the
> VenueManagement to VenueServer,i encounter some problems which i fail to
> understand. i would be grateful if some one could provide some insights.
> When the VenueManagement tries to connect to the VenueServer, the
> ioc.tcp_connect call in GSIHTTPConnection.connect fails. ( " Thas what i
> made of the debugger dumps that I saw !")
> the logs of the script in the debugger are as follows:
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(660)connect()
> -> ret, handle = ioc.tcp_connect(host, port, attr.get_handle())
> (Pdb)
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(1223)get_handle()
> -> def get_handle(self):
> (Pdb) s
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(1224)get_handle()
> -> return self._handle
> (Pdb) s
> --Return--
> /usr/lib/python2.2/site-packages/pyGlobus/io.py(1224)get_handle()->'_d05b8908_p_globus_io_attr_t'
> (Pdb)
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(661)connect()
> -> if not ret == 0:
> (Pdb) p ret
> -1
> (Pdb) s
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(662)connect()
> -> ex = GSITCPSocketException(handle)
> (Pdb) p handle
> 'authentication failed:\n Authentication Failed\n GSS status:
> major:000a0000 minor: 00000000 t
> oken: 00000000\n'
> (Pdb) s
> > /usr/lib/python2.2/site-packages/pyGlobus/io.py(663)connect()
> -> raise ex
> (Pdb)
> GSITCPSocketException: <pyGlobus.io.... at 0x8a102e4>
> -> raise ex
> (Pdb) c
> Unable to Connect to Server https://arbit.cse.iitd.ernet.in:8000/VenueServer
> Is There some known bug OR some configuration problem ?
> MOREOVER , when I click on the "CHECKPOINT" option , I get a error similar
> to :
> major:000a0000 minor: 00000000 token: 00000000\n'
> Please help me I am in urgent need of some help !
> Thanks
> Regards
> Himani
> On Mon, 1 Dec 2003, Ivan R. Judson wrote:
> > Date: Mon, 1 Dec 2003 08:23:15 -0600
> > From: Ivan R. Judson <judson at mcs.anl.gov>
> > To: 'Himani Gandhi' <csa02037 at cse.iitd.ernet.in>, ag-tech at mcs.anl.gov
> > Subject: RE: [AG-TECH] Certificates for simple CA
> > Hi Himani,
> > Currently the AGTk does not support making requests to a certificate
> > authority other than the ag developers ca. You would need to request the
> > certificate from that CA using whatever means are available (perhaps
> > grid-cert-req if you have it setup, or the CA might have a request process
> > outlined).
> > We will consider steps necessary to make this possible in the future.
> > Thanks,
> > --Ivan
> > > -----Original Message-----
> > > From: owner-ag-tech at mcs.anl.gov
> > > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Himani Gandhi
> > > Sent: Saturday, November 29, 2003 7:03 AM
> > > To: ag-tech at mcs.anl.gov
> > > Subject: [AG-TECH] Certificates for simple CA
> > > HI all ,
> > > I wish to generate certificate to be submitted to the simple CA ,
> > > on another LINUX machine here . I have imported the Trusted
> > > Cert file (.o)
> > > and the signing policy file to the directory of trusted Certs.
> > > What else is to be done to generate certificate requests for
> > > a simple CA
> > > and not the CA at Argonne ?
> > > Regards
> > > Himani Gandhi
