[AG-TECH] AGTk 2.1.1a for windows
Eric Olson
eolson at mcs.anl.gov
Wed Aug 27 10:58:26 CDT 2003
Hi all,
We'll have an install that fixes these two things as soon as possible,
but until then, here are simple workarounds.
1) Unable to register type library msvr70.dll.
Just disregard unless you get later errors about a missing msvr70.dll (if
you do, you can copy it from another window's machine or ask us for it.)
2) Unable to locate AGServiceManager.
This can be fixed by changing the VenueClient shortcut's "Start in:"
option to "C:\Program Files\Access Grid Toolkit\bin" (if needed, replace
"C:" with your correct drive letter).
Eric
On Wed, 27 Aug 2003, Cindy Sievers wrote:
> I get the same error. I also get an error when I try to run the venue client
> "Application unable to determine location of AGServiceManager. If you
> installed using a windows installer, this is due to a bug in the
> installer. If you are running from a CVS checkout, check the value of
> AGTK_INSTALL environment variable."
> At 06:16 AM 8/27/2003 -0500, Randy Heiland wrote:
> >Sorry for my basic ignorance in Windows-land, but I never had a problem
> >with "the missing msvcr70.dll" when I installed 2.1.1 on XP. So, now
> >when I try to install this 2.1.1a pkg, I get the error:
> >c:\windows\system32\msvcr70.dll
> >Unable to register the type library...
> >Do I simply disregard this and proceed?
> >thanks,
> >--Randy
> >On Tue, 2003-08-26 at 16:13, Ivan R. Judson wrote:
> > > We've put out a very minor update, that includes the missing msvcr70.dll
> > > that was needed by the windows installer. The new package is at
> > http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.1/window
> > > s.html
> > > --Ivan
> > > PS -- Thanks to Sam Fulcomer for finding, fixing, and reporting this
> > > problem!
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
